Starter Proplems/kickback?
Old Sep 27, 2008 | 09:41 AM
tgaetto's Avatar
tgaetto
Default Starter Proplems/kickback?
I did a 24t comp sprocket and since my starter has progressively been getting worse? It has been kicking back and sort of grinding?
I have compression releases and it is the same either closed or open? I have checked all connections and battery tender always plugged in?
Doesn't want to stay engaged?
Old Sep 28, 2008 | 09:40 AM
Ultra007's Avatar
Ultra007
My '07 has been doing the same thing. Tried retarding the ignition timing to no avail. Dealer says theyhave beebn seeing more of this. MoCo told them to check the starter bolts for excessive powder coating or something. Didn't help mine. It will even blow oil smoke back out thru the intake. I NEED HELP TOO!
U
Old Sep 28, 2008 | 11:02 AM
miacycles's Avatar
miacycles
The starter drives the clutch hub which has a large sprocket, the compensater has a smaller sprocket. Changing the compensater to a smaller sprocket increases the mechanical advantage of the motor. It also increases the mechanical advantage the motor has over the stock starter. Basically you decreased the ratio that the starter had over the engine. The best cure (if everything is aligned properly) is to go to a bigger starter. Hope this helps.
mballard
Shovelhead
31
Jun 6, 2019 08:01 PM
FL54
Shovelhead
44
Jan 24, 2018 08:31 AM
lebert
Aug 7, 2010 07:03 AM
02glide
Oct 26, 2006 01:00 AM
plya5632
Welcome Area Only
Oct 16, 2004 08:32 PM
