Cigarette Lighter as a power outlet?
Old Sep 29, 2008 | 09:21 AM
ghostflamed's Avatar
ghostflamed
Default Cigarette Lighter as a power outlet?
I was surprised to read in my 2009 Road Glide's owners manual that HD does not recommend using the cigarette lighter as a power outlet site. I was hoping to run my heated vest or charge my ipod, etc with this lighter. Any thoughts from the collective wisdom here?
Old Sep 29, 2008 | 09:27 AM
HDUltraRider's Avatar
HDUltraRider
I have an 07 and run both my heated gear as well as charge my ipod from the cigarette lighter with no issues. The one recommendation I can make is make sure you put some felt on the back of your thermostat or switch to the heated gear because if it rest on your gas tank it will rub and leave marks. Trust me I know from experiance.
Old Sep 29, 2008 | 10:00 AM
08UltraRider's Avatar
08UltraRider
Yes and the manual also says you shouldn't pull a trailer with a motorcycle either...
A logical reason to me, and seeing we both get the same manual for touring models, is that an adapter plugged into a batwing fairing could interfere with the steering albeit that would not hold true with your RG sharknose fairing.
Old Sep 29, 2008 | 10:05 AM
007 ultra's Avatar
007 ultra
YUP - - that is a cute one. HD says not to pull a trailer and they sell the trailer hitch/wiring as an accessory.
Can you say Oxymoron? :-)
Old Sep 29, 2008 | 01:46 PM
roxnatwist's Avatar
roxnatwist
It's got to be some sort of liability issue...but then again, I'm shocked they still call it a cigarette lighter-
Old Sep 29, 2008 | 02:01 PM
RottMan's Avatar
RottMan
Speaking of the Cig Lighter...I was hooking up my hidden antenna and the ground wire touched the back of the lighter and sparked. Now the lighter doesn't work. I'm assuming I blew a fuse. Any idea where I can locate it to replace? Yeah, I know, why was the power on in the first place. I had to have the radio on to determine where best to mount the antenna.
Old Sep 29, 2008 | 02:12 PM
Thirdup's Avatar
Thirdup
I think the batwing cig lighter runs off the 15 amp "acc" fuse.
Right side cover.
Old Sep 29, 2008 | 02:13 PM
Bertk's Avatar
Bertk
The owners manual with show the location of the fuse box on the bike and what each fuse protects.
Old Sep 29, 2008 | 02:40 PM
RottMan's Avatar
RottMan
Why didn't I think of that?! Thanks.
Old Sep 29, 2008 | 03:02 PM
Bertk's Avatar
Bertk
You would have!
