Road King Quick-Release Windshield
Old Mar 27, 2005 | 09:53 AM
rose225's Avatar
rose225
3rd Gear
Default Road King Quick-Release Windshield
I have an '03 RK with a quick-release windshield, which I can't get to stop vibrating. Any recommendations (other than replacing it with a fixed mount windshield)?
Old Mar 27, 2005 | 11:30 AM
TexasBowhunter's Avatar
TexasBowhunter
Default RE: Road King Quick-Release Windshield
have you checked the nylon gromettes?
They might be worn...
See if you can narrow it down to which side and then where its comming from...
That is if you havent allready tried it...
Good luck
Old Mar 27, 2005 | 11:45 AM
rose225's Avatar
rose225
3rd Gear
Thanks for the feedback, but if anything I think that it may be the quick release "springs," which work themselves up off the gromettes ever so slightly, which then causes the vibration (on both sides, altough worse on one).
Old Mar 27, 2005 | 11:55 AM
pilot1996's Avatar
pilot1996
Don't have a RK, but wanted to welcome you to the forum.
Mac
Old Mar 28, 2005 | 08:05 PM
Retired_Ted's Avatar
Retired_Ted
It doesn't look as though the springs are much more than "clamps" which keep the windshield from being pulled off unless sprung upward. My vote would be to replace the docking hardware which is supposed to dampen those vibrations. I'd also check to torque of all the windshield hardware itself.
Old Mar 29, 2005 | 12:05 PM
jeepwatchman's Avatar
jeepwatchman
Check to make sure you have it mounted correctly on the bike. What I mean by this is make sure it is on there squarely and both mounts are where they should be. You also might try taking it off and then putting it bacl on again. I have a RK standard and don't have any problem with vibration here in windy Wyoming.
Old Mar 29, 2005 | 11:40 PM
mikeisglidn's Avatar
mikeisglidn
id tend to think its a mounting problem, when its mounted correctly, them babies are pretty snug!
SmittyFXDL
Sep 26, 2015 07:07 PM
gjetson
Feb 26, 2012 06:27 PM
GPHDXLC
Long Ride Shields
Jan 7, 2011 01:54 PM
joker1450
Sep 30, 2008 03:48 AM
ultrajoe2009
May 31, 2007 08:24 AM
