Bizarre Ultra behavior
Old Oct 5, 2008 | 05:18 PM
Ram's Avatar
Ram
You should take a look at the gas before going any further. It is quick and almost the least expensive thing to do at this point. Just drop the left side tank cross over hose and fill a glass mason jar. Let stand for a min. Gas and water will separate, and water will settle to the bottom if you have some. I did mine early on when first got my bike and found almost a quart of water in the bottom of the tank.
Even if you don't find an appreciable amount of water at the bottom nothing to say you still don't have some some place in the tank, run some "Heat" or "Dry Gas" through the tank and then some "Sea Foam" to clean the injectors.
If that does not clear up the problem then you can start some more (costly) agressive trouble shooting.
OBTW what is the current condition of the plugs?
Old Oct 5, 2008 | 05:25 PM
SMenasco's Avatar
SMenasco
It sounds like an electrical problem to me. Disconnect the EFI connector under the right hand side cover and spray both male and female connections with silicone lubricant. There's a possibility a piece of dust may have gotten in there, since it's usually pretty dirty inside the cowling,
Old Oct 5, 2008 | 05:55 PM
Wulf's Avatar
Wulf
Something to think about; my 04 Softail ignition switch was cutting out. I pulled it apart and cleaned the contacts and added dielectric grease. I never had a problem since. The dealer said the switch was only available with a new lock cylinder and I didn't want to spend the money for it
Old Oct 5, 2008 | 06:21 PM
HB's Avatar
HB
Check all of your fuses to make sure they are in tight and clean the terminals.
Old Oct 5, 2008 | 06:38 PM
Ultra Will's Avatar
Ultra Will
Thanks to all for the suggestions. We will begin to check everything out in the morning.
Old Oct 5, 2008 | 07:05 PM
zoozoo's Avatar
zoozoo
Make sure you have a good ground connection to the frame.
Old Oct 5, 2008 | 07:35 PM
will2002's Avatar
will2002
For DJH1960... My 02 Ultra had the very same problem. I put in a new MAIN BREAKER, under the seat. Cost about $3.00. Problem solved.
Old Oct 5, 2008 | 07:44 PM
melkels121's Avatar
melkels121
2nd Gear
Default Stalling Ultra
Originally Posted by Ultra Will
My son and I took a 100 mile trip yesterday and he wanted me to ride his 06 Ultra. To make a long story short, while riding it would just stop running for maybe less than a second. It did this five times within the 100 miles. It was almost unnoticeable because of the short duration. At first I thought it was just the wind, but the bike actually died for a split second. Is this likely to be an electrical or fuel malfunction? He just had new injectors installed 300 miles ago due to a recall. Could this have anything to do with it? Anyone ever experience this? Help.
Had a freind who has had the same problem with his 07 Ultra. They had to change out the kill switch on the handlebars. Several dealers suggested and did other things before they finally found the problem.
Old Oct 5, 2008 | 08:47 PM
bigskyhd's Avatar
bigskyhd
+1 on connection to the frame. Easy to check the battery end, often fail to check the other end. Let us know. Don't think it's the crank position or cam position sensor. Usually the bike won't start when they go bad. It will turn over and over, but just not start, like not having any gas at all. FWIW..
Old Oct 5, 2008 | 11:14 PM
goodbirds's Avatar
goodbirds
Lightbulb
I've had my bike "shut off" twice since I've owned it. First time was about two weeks after delivery, and the second time about a year later. Like hitting the kill switch. The tach and the speedometer both go to zero. Shop says no codes or other problems show up during the diagnostic. It is a mystery.
Turn off and on the ignition switch, and starts right back up.
