Shift lever Shaft
Old Oct 7, 2008 | 01:26 AM
PDDGM's Avatar
PDDGM
Default Shift lever Shaft
I managed to break the end off the shaft that hold the toe/heel shift levers tonite. the toe shifter stripped out and dropped down resting on the lower, when I tried to pull it back up, it jammed. Unable to get to the allen bolt, so put a bar under the shifter lever and tried to work it up enough to get in 1st or 2nd gear(was stuck in fifth). Guess I am stronger that I look, it snapped off leaving just enough to get the heel shifter on and the bike the rest of the way home. My question is: how hard is it to install a new shaft? I am going to replace the lever or shaft that goes into the tranny real soon. I guess a new shift lever is in order also, sure don't make Harley's like they used to...LOL..Any help appreciated.....
Joe
Old Oct 7, 2008 | 01:43 AM
SoCal_Pappy's Avatar
SoCal_Pappy
If your talking about the shaft that the Heal\Toe levers are connected to... Then it's a easy replace - I stripped on out on my '01 many moons ago...
Old Oct 7, 2008 | 06:07 AM
Point Man's Avatar
Point Man
i just did mine yesterday, only because there was a lot of play in it (25K miles on an '05). Get a new shaft and also I'd suggest getting a new rubber spacer bushing too. That's what I did and that heel/toe shaft assembly is now tighter than a nun's ***! Oops...bad analogy..but you get the picture! The shaft is about $17.00....
Old Oct 7, 2008 | 06:21 AM
harley-jones's Avatar
harley-jones
Unbolt front transmission linkage rod from leaver.
Unbolt leaver from cross shaft that the linkage was bolted too.
pull shaft.
This should be a real easy repair for you.
Old Oct 7, 2008 | 09:11 PM
PDDGM's Avatar
PDDGM
Default Thanks
Thanks for the info. I called a dealer today and got the cost on the shaft at 17.21 and the shift lever at 42.00 . Will go tomorrow and pick up the shaft, but will get a lever off ebay or at a independent shop.
Joe
Old Oct 7, 2008 | 10:47 PM
dawg's Avatar
dawg
Many a folk remove their heel shifter and may give it to you or sell it to you cheaply.
Old Oct 9, 2008 | 04:42 PM
PDDGM's Avatar
PDDGM
Default Repair done
Well, I went up to Lake Ozark Harley to day and got the new shaft, looked at the chrome spacer but decided against the HD one. Stopped at the Ace Hdwe and checked out the boxes of speciality items in fastners and low and behold they had an assortment of chrome spacers, that just fit the OD of the shaft, bought 3 different sizes for under 10.00 and got home and put the shaft in with the spacers until I got it the way I wanted it. I put the heel shifter on flush with the end of the shaft and added spacers until it rested against the black rubber spacer. Put the shifter rod lever back on and tightened everything up. Seems to be ok, will ride it tomorrow to work and see. But am taking a bunch of tools with me...LOL...
Again thanks to all that gave me advise.
Joe
cwsharp
Aug 22, 2022 11:54 PM
Damien Morrissey
Sep 10, 2019 12:49 AM
Road Star
May 10, 2014 09:52 AM
jacknthebox
Aug 24, 2013 05:28 PM
CT-Bagger
Sep 13, 2012 09:35 AM
