Removing heel shifter - got a question
Old Aug 24, 2013 | 03:41 PM
jacknthebox's Avatar
jacknthebox
Default Removing heel shifter - got a question
My toe shift lever is stripped - the shaft is still good - so, rather than pay for a new shift lever and for a cheap temporary fix I removed the toe shift lever and moved the heel shift lever in its place - BUT, this poses a problem: the space between the shift lever and the shaft housing is too great now and so the shaft moves left to right way too much - can I just add another spacer to fill the gap or is there a longer spacer for my application?
Old Aug 24, 2013 | 03:53 PM
mkguitar's Avatar
mkguitar
there are spacers available for this common modification.
or the cheap guy says, take your worn lever and cut the shifter part of it off and use the collar as the spacer
mike
Old Aug 24, 2013 | 04:03 PM
Jerry1834's Avatar
Jerry1834
The spacer is cheap enough and they make plain and fancy.....plain worked for me.
Old Aug 24, 2013 | 04:12 PM
Jerry1834's Avatar
Jerry1834
Dup posted deleted
dawg's Avatar
dawg
I use a piece that I cut off of a wind chime. I'm a real a cheap bastard.
Old Aug 24, 2013 | 04:45 PM
jacknthebox
mike
Thanks all! If I would've looked at it harder I would've remembered that the toe shift lever was the inner and the heel lever was the outer - so, in putting the lever closer to the housing rather than further, the spacer fits and all is good.
Old Aug 24, 2013 | 05:25 PM
GuNsLiNgEr420's Avatar
GuNsLiNgEr420
Old Aug 24, 2013 | 05:28 PM
GuNsLiNgEr420
I am from the softail world with extended forward controls. So when I got my Street Glide a few months back, I could not get use to the heel shifter so I removed the heel shifter and made a spacer by cutting a piece of an old set of Aluminum risers and used that as my spacer. You can use just about anything that will slip over the shaft...
Frank the Real Biker
2014-2024 Touring Models
22
Apr 4, 2016 01:57 PM
Road Star
May 10, 2014 09:52 AM
DaSham58
Dec 19, 2008 01:34 PM
PDDGM
Oct 9, 2008 04:42 PM
Cue
Jul 18, 2008 11:36 AM
