09 heated grips
Old Oct 8, 2008 | 09:24 PM
hognut's Avatar
hognut
5th Gear
Question 09 heated grips
Has anyone put heated grips on a 09 the catalog says not for internal wiring. I'm not sure if the fly by wire throtle will get in the way?
Old Oct 8, 2008 | 09:25 PM
hognut's Avatar
hognut
5th Gear
on a 09 ultra classic
Old Oct 9, 2008 | 11:22 AM
Peppa1's Avatar
Peppa1
That just means you can't use them if your are running all your other wires inside your handlebars. If you are just going to add these grips to the stock handlebars you will be fine. Some go with the larger diameter handlebars and run all their wires (swithes etc) inside the bars for a clean look.
Old Oct 9, 2008 | 11:38 AM
Raaze07's Avatar
Raaze07
Thanks, I've been wondering the exact same thing myself. Although I'm not sure how the CVO Ultra's can have heated grips, don't they all have internal wiring (bars are clean)?
Old Oct 9, 2008 | 02:25 PM
Peppa1's Avatar
Peppa1
Not 100% sure but they may have the 1 1/4 - 1 1/2 bars on them and that gives you the extra room needed to run everything internally. The standard 1" bars will make for a tight squeeze.
Da Shadow
Feb 2, 2013 01:37 PM
apopj
Feb 25, 2010 08:50 PM
jbird79
Jan 1, 2010 04:14 PM
Born2cure
Mar 13, 2009 10:45 PM
Toytech
Sep 25, 2005 12:33 AM
