WO575 vs HD Pullback Bars
Old Dec 15, 2008 | 07:25 AM
  #51
peddler's Avatar
peddler
bertk: Great post. You mentioned removing the wires from the Molex connectors. Did you extend the wires before reinstalling? Were you able to reinstall the connectors at the original position in the fairing? You also included the pages fromthe Service manual for crimping new pins for the Molex connector. Did you replace the pins or reuse the old ones?
Alot of questions. I'm working my way thru installing Wild One 575's. Same installation in this case without TBW. Slightly different bars.
Thanks for the info
Old Dec 15, 2008 | 09:53 AM
  #52
sporty06's Avatar
sporty06
I would go with the Khrome Werks Wide Sweeper +2. You will need the +3 clutch cable according to the Khrome Werks folks. I have the sweeper +2 on my Roadglide and really like the looks and feel.
sporty06
Old Dec 15, 2008 | 10:22 AM
  #53
Bertk's Avatar
Bertk
No, I did not extend the wires for the handlebar controls.
The connectors for the controls had to be relocated. If I had it to do over I would most likely get the extensions.
You also included the pages from the Service manual for crimping new pins for the Molex connector. Did you replace the pins or reuse the old ones?
There's no crimping needed. Using the instructions (page A.10 in the 08 manual) in the Service Manual the pins can easily be removed from the Molex connectors, then reinserted for running the wires internally. Just make note of the pin locations.
No problem, keep the questions coming.
Old Jan 23, 2010 | 12:24 AM
  #54
Capecodgirl's Avatar
Capecodgirl
GREAT POST!! I too started a Thread on bars just the other day! I am looking to find some bars that come closer to me at 5"5 It's not horrible, but I think it will stop me from locking my elbows.
I appreciate all your experience and knowledge. Love the PICTURES TOO!
Old Jan 23, 2010 | 08:23 AM
  #55
peddler's Avatar
peddler
follow up to my 12-15-2008 post:
The WO575 bar swap turned out to be a great project. Purchased wire extensions from NAMZ. Probably didn't need to if I didn't care about reinstalling the connectors in the orginal fairing position. Made one splicing mistake that took a while to correct. Hadn't read this thread in a while. I don't actually remember noticing the wrist angle change with the WO575. Guess it wasn't noticable.
Great bars. I wouldn't do anything different if I had to do it all over again.
Old Jan 23, 2010 | 09:03 AM
  #56
kjtoys's Avatar
kjtoys
i like my 575 wild ones. I have them on an 07 street glide and can still use the inner fairing mirrors. The harley ones are 1" diameter and look like juck to me.
Old Jan 23, 2010 | 09:04 AM
  #57
kjtoys's Avatar
kjtoys
i like my 575 wild ones. I have them on an 07 street glide and can still use the inner fairing mirrors. The harley ones are 1" diameter and look like junk to me.
Old Jan 23, 2010 | 09:59 AM
  #58
Wally's Avatar
Wally
I have them on my Ultra, they are a real nice mod, quality product, and there is lots of info on here on how to instal them yourself, which is what I did.
Old Jan 29, 2010 | 03:38 PM
  #59
2manytoys's Avatar
2manytoys
New to this forum but have read it many times regarding the WO 575's. I needed a couple inches more pull back to get rid of the pain between my shoulder and neck. (bad back as well)
I just had my dealer install them on my 09 SG with ABS. They charged me 3 hours labor plus a +4" clutch cable. Stock TBW wiring and brake lines worked just fine. Thought you'd like to know.
Old Jan 29, 2010 | 07:04 PM
  #60
peddler's Avatar
peddler
Hope you like the bars. Surprised about the stock brake lines. 3 hours could be a world's record however without having to extend the wiring that would reduce the amount of time required. Good luck with them.
