Handlebar installation
Old Oct 24, 2008 | 06:29 AM
  #31
ironhead3fan's Avatar
ironhead3fan
So if I wanted to do true duals, now would be a good time I guess.
Old Oct 24, 2008 | 07:08 AM
  #32
timvan's Avatar
timvan
Didnt have to remove the pipes on my 09, just the heat shield. Had great access to the tranny cover with a ball end allen T
Old Oct 24, 2008 | 08:27 AM
  #33
bazam9s's Avatar
bazam9s
Be careful...there you go down that slippery road!!!
Old Oct 24, 2008 | 11:11 AM
  #34
Bertk's Avatar
Bertk
I am a fan of true duals, so any time is a good time to switch. If you can change the clutch cable you can install true duals.
Here are some tips if you go that route.
1. Get two new flange gaskets while your at it. HD PN: 65324-83A
2. Make sure the pipes are aligned correctly where they connect to the head to avoid leaks.
3. If you go with V&H, do not use there muffler clamps.
Purchase new H-D Torca clamps: 65283-94 and torque to 45-60 FT. LBS.
Exhaust leaks can produce popping on deceleration.
4. A 1/2 inch stubby combination wrench will come in very handy on the rear lower head bolt and rear support bracket adjustment.
A 1/2" swivel socket will come in handy also.
5. Flange tightening process:
Tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs.
Tighten the bottom nut to 100-120 in-lbs
Then the top to 100-120 in-lbs.
6. Before tightening the rear pipe install the left side cover and check the
clearance between the pipe and the cover.
7. This photo will help when it come time to install the rear pipe support bracket.
Once it's done, your going to love them.
Old Oct 24, 2008 | 11:16 AM
  #35
Bertk's Avatar
Bertk
That's good to know about to 09's. That saves a lot of work.
Old Oct 24, 2008 | 02:54 PM
  #36
sifularson's Avatar
sifularson
Originally Posted by Bertk
I emailed the folks a Speed Bleeder and the part number for the Brembo brakes is SB8125L. Received them in the mail yesterday and may install them tomorrow.
I found the bleeders also. Ordered a set so I can get busy installing the Brembo set-up on my 07.
Did you get the bag and hose? Makes it real easy to bleed the brakes or change the old fluid. The service manual says to change DOT 4 every 2 years.
Old Oct 24, 2008 | 06:11 PM
  #37
ironhead3fan
Yeah, yeah, I know, but I really haven't spent too much over the years. I am adding some pullback handlebars now. I have added some chrome, upgraded speakers, bought a zumo, slip ons, Mustang seat, backrest, all the 100th anniversary goodies, and a V & H Fuel Pak. No motor work, so I haven't spent the real dollars yet. As of now, I have no plans to. Runs fine as it is.
If I already have the exhaust halfway off while putting in this new clutch cable, no sense in doing it again later. If I think I might want true duals, this would be a good time. I have been staring at the ebay page off and on most of the day. Haven't pulled the trigger yet, trying not to spend too much.
Decisions, decisions.
Old Oct 24, 2008 | 09:20 PM
  #38
Bertk's Avatar
Bertk
Yes, got the hose and bag kit and it worked very well. The Speed Bleeder part number for the Brembo brakes is SB8125L, front and rear. The OEM bleeders have an o-ring where it contacts the caliper. This o-ring is for factory bleeding only, and should be discarded when new bleeders are installed.
Before removing the old bleeder I hooked up the hose and bag and let the old fluid drain into the bag. Then pressed the brake handle or force more fluid out. With the new Speed Bleeders installed I cracked one open a 1/4 of a turn but enough pressure would not build up to open the check valve in the new bleeder. Unscrewing the new bleeder enough to let some air out and tightened the bleeder. Then starting the bleeding process again and that did the trick.
The rear did not have to be pre-drained because the bleeder is above the reservoir. I did note there was a good amount of moisture under the master cylinder cover and on the top side of the cover gasket.
I ended up using DOT 4 synthetic brake fluid, flushing out all the old fluid in the process. The Speed Bleeders worked as advertised.
The bikes a little over a year old and I'm going to repeat the brake fluid flush and bleed every year. The Speed Bleeders will make this very easy.
Old Oct 24, 2008 | 10:52 PM
  #39
sifularson's Avatar
sifularson
Did you use Amsoil Dot 4?
http://www.amsoil.com/storefront/bf4.aspx
BTW, I hope you meant synthetic and not silicone. My 04 sportster used DOT 5 silicone. My 07 Road Glide uses DOT 4 glycol based fluid.
Old Oct 24, 2008 | 11:43 PM
  #40
Bertk's Avatar
Bertk
I used Prestone DOT 4 synthetic
Minimum Dry Boiling Point 500F (260C).
Minimum Wet Boiling Point 311F (155C).
Meets or exceeds DOT 3 and DOT 4 specifications.
Substantially reduces the possibility of fluid vaporization and eventual brake failure (as a result of vapor lock) by maintaining a high wet boiling point.
Recommended for all ABS, disc and drum brake systems as well as hydraulic clutches requiring DOT 3 and DOT 4 fluids.
Compatible with all conventional brake fluids.
Complies with Federal Motor Vehicle Safety Standard 116, Meets SAE Spec, J1703.
