Help
Old Oct 20, 2008 | 02:13 PM
a_little_odd's Avatar
a_little_odd
Stage II
Default Help
Hey if any body could help. I am a new owner of an 08' electra glide got one problem with her though. I am short legged and rumor has it you can adjust the shock height. Is this true and if it is how can I do this without haveing to spend a bunch of money on new shocks if they arent needed? And I am also looking for some addvice on the fact that I want to change off the factory pipes I am looking for a beefier sound. Does any one have any suggestions as to what to put on?
Old Oct 20, 2008 | 02:18 PM
ord sgt's Avatar
ord sgt
Did you get the owners manuel with the bike? If so, the answer should be in there.
Old Oct 20, 2008 | 02:20 PM
Thirdup's Avatar
Thirdup
Lowering is going to consist of either shorter shocks or lowering bracket kit (you may get mixed reviews on either depending on road condition, riding solo-vs-2up, etc).
For beefier sound, toss on some slip-ons (ie: Rush with a 1.75" - 2.0" baffle). You don't need to change out the whole exhaust system
Old Oct 20, 2008 | 05:57 PM
a_little_odd
Stage II
Thank you guys. No I didn't geet an owners manual with it, Technical it is a used bike but will look into it thanks for all the help.
Old Oct 20, 2008 | 06:35 PM
bigskyhd's Avatar
bigskyhd
Try changing the seat to lower you. You can get some cheap seat to see if it will help, and then upgrade to the model you want once you find out.
Old Oct 20, 2008 | 07:34 PM
Zimbob's Avatar
Zimbob
Go to a local bike night and check out the scoots there. That will give you a better idea of what you want and you get to see it real close, not just some picture. Talke to the others there, they'll be happy to tell you all about their bike.
DieselJoe
Aug 20, 2015 06:02 AM
NarleyDavidson
Jun 6, 2011 01:46 PM
armyhooah
May 15, 2011 11:23 AM
lionpride1985
Mar 20, 2009 07:17 AM
Chaplain Wayne
Aug 12, 2005 03:19 PM
