Need Help For Rear Tire Replacement
Old Nov 15, 2008 | 09:02 AM
catracho's Avatar
catracho
Exclamation Need Help For Rear Tire Replacement
My near HD dealer is out of tires. Need to replace my rear tire, the code is D402 MU85B16
and I want to know if a 150 / 80 / B16 will work for me.
Thanks,
Old Nov 15, 2008 | 09:24 AM
petemac's Avatar
petemac
Why not just go to another dealer? Or have your dealer order you a tire, can't take that long.
Old Nov 15, 2008 | 09:32 AM
anubisss's Avatar
anubisss
That should work. The 150 refers to the width of the tire and the 16 is the diameter. Look at your old tire and it should say the size on it.
Old Nov 15, 2008 | 10:51 AM
ngoti8tor's Avatar
ngoti8tor
Some guys on here say you can put a car tire on it. I wouldn't do it myself though, I'd find a bike tire.
Old Nov 15, 2008 | 11:02 AM
geedee's Avatar
geedee
Other than a need to replace in a emr....why not order the one on the bike?
Old Nov 15, 2008 | 11:19 AM
Uncle Scrooge's Avatar
Uncle Scrooge
150-80 will fit barely. But the load rating is substantially less. Not recommended, especially if you're going two up.
Old Nov 15, 2008 | 12:43 PM
younggeezer's Avatar
younggeezer
If I'm right the MU85B16 is a 142mm tire, I bet the 150 would be a tight fit. I read somewhere that the MU85B16 is a higher load rating and it is a different compound tire that is supposed to give up to 35% more tread life. I ordered my last several tires from www.jakewilson.com , they will ship free any order over $99. If your not in too big a hurry you could probably save yourself some cash ordering your own.
Old Nov 16, 2008 | 08:35 AM
leon anthony's Avatar
leon anthony
you can shop around and get it for aroung 140, dollars but that is tire in hand
you still have to get it on the bike if you have it done that will be around 80 dollars
I put mine on myself. and use dyno beads for balance
Old Nov 16, 2008 | 08:48 AM
johnnyhonda's Avatar
johnnyhonda
Call Tim @ www.twobrotherstires.com and he will fix you up. I ordered a set on a Thursday and they were sitting on my front step Friday afternoon. Great service and you can't beat his prices.
Old Nov 16, 2008 | 09:33 AM
HB's Avatar
HB
Check the E3's. Go to the Dunlop website and lookup info on the 402 then look at the E3 that is comparible in size and ratings. A lot of people are happy with this tire. Do a search and you will see. i am going to these next time. Some are getting double the milage of the 402's.
pervy_ninja
Jul 21, 2013 10:43 PM
piccmc
Aug 8, 2011 02:00 PM
rearnold
Jul 6, 2011 06:16 PM
1flhtk4me
Jul 29, 2008 04:44 PM
Anthony8858
Nov 17, 2005 06:41 PM
