How do you know when the Engine Idle Temp Mngnt System is active?
Old Nov 20, 2008 | 08:08 PM
05LowRider's Avatar
05LowRider
Originally Posted by ezriderpgh
If you try to pull off from a stop sign or signal and the response is close to a mini-bike, you know it's active.
I don't know why some of you are experiencing a power loss when you take off from a stop. The rear cylinder should go back to normal operation as soon as you touch the throttle. At least, that's what HD says.....and mine does.
Old Nov 20, 2008 | 11:45 PM
BigD64's Avatar
BigD64
You can tell if it's activated by turning on the ignition switch then rotating the throttle forward for 3 seconds. You should see a green or a red light on panel. Red means it's off green for on. This is also how you turn it on and off.
Old Nov 21, 2008 | 07:48 PM
pbsdaddy's Avatar
pbsdaddy
Actually, I thought it was more like........ puh...puh...puh. Rather than to...to...to
Hogdoc45
15
Nov 15, 2018 07:21 AM
Jerry Nokes
Engine Mechanical Topics
Oct 29, 2014 09:50 PM
indigofarm
Jan 18, 2011 11:59 PM
tririder
May 15, 2009 07:20 AM
Dionicio
Mar 4, 2008 06:23 PM
