1998 Ultra EFI to CARB conversion
Old Nov 26, 2008 | 12:29 PM
tibbs's Avatar
tibbs
6th Gear
Originally Posted by jdreed520
I bought the Screamin Eagle ignition module and it plugged into the harness and used my stock ignition plate. I did not have to change anything else on the bike.
I just got mine started. I had to change the rotor cup to part#32402-83 and move the ignition plate from the stock non adjustable mounting holes to the slotted holes...static timed it and she fired right up this morning. I found all the stock parts from a 98 fatboy on ebay for less then $200. I running a custom bike...my own wiring harness... so I just ran the wires from the stock ignition module to where they needed to go ...piece of cake. The only problem I am having is I am getting hesitation when I first crack the throttle...I guess I need to adjust the mixture screw.
-Matt
Old Sep 18, 2023 | 01:21 PM
notwincams's Avatar
notwincams
2nd Gear
You guys are making it sound difficult. Its not. First but the conversion kit for gas tank that eliminates pump and the two fuel lines. Then throw away efi intake and all its components. Slap on a s&s carb and intake then throw away that ignition brain box it has and any efi wiring.
Put a dynatek or twin tech ignition in the nose cone of bike. Run the 4-5 wires and its down the road. No need to worry about getting complex on the wire harness
Old Sep 18, 2023 | 01:50 PM
Screamin beagle's Avatar
Screamin beagle
Awesome man thanks...after 15 years I finally found the courage to fix my bike and its all thanks to you. I don't know what you do for a living but idle it's not a motivational speaker then you missed your true calling.
Old Sep 18, 2023 | 04:59 PM
Rains2much's Avatar
Rains2much
OP.. you go right ahead. Forget the ney sayers.
Here’s the math.. dude with fuel injection or throttle body spends $500 with a tuner.. he has to make an appointment.. possibly drive 2-6 hours to this tuner.. is he a good one? He has to wait on him.. and once done he can’t make any changes..
OR
He grabs his bean can filled with jets and make the adjustments right there
They both make the same power.. but you decide.
Old Sep 18, 2023 | 06:23 PM
Stiggy's Avatar
Stiggy
Op hasn't been around for nearly 15 years
Old Sep 19, 2023 | 07:55 AM
Rounders's Avatar
Rounders
OR
I used to adjust my SERT and go for ride, just like what a carbed person does.
You can crudely tune fuel injection to the low level of a carb. Dyno is for people who want more. People dyno cabs too.
Go get canned generic map, no worse than choosing between a couple different jets, needle, and half turn of a screw.
Yes carbs are easy, cause you don't have a lot of options .
I think silly to rip out Delphi. But people used to do it. MM now a days I might rip out
Old Sep 19, 2023 | 08:02 AM
Rounders's Avatar
Rounders
I have wondered why you can't buy carb, bung hole converter, petcock, cables,and ignition, abandoning fuel injection in place. Not saying that is all inclusive parts list.
But I am sure more to it. You can probably find 20 year old threads with parts listed . I suspect it adds up.
Probably easier to figure out on pre 2007 bikes, follow manual to some degree.
Old Sep 19, 2023 | 08:04 AM
Rounders's Avatar
Rounders
I know a mechanic who has turned down this job. I suspect the non wrenching hours add up to more than customer wants to pay
Old Sep 19, 2023 | 10:02 AM
glasspilot's Avatar
glasspilot
I agree. My Delphi (2006) is bullet proof, and they were used many years. So you can still get parts.
If I had a MM Harley and had problems I would look seriously at an S&S carb conversion.
slyder
Feb 3, 2013 10:49 AM
Ibuiltmine
Exhaust System Topics
Mar 31, 2012 05:10 PM
soundman
Jan 9, 2009 07:43 PM
ColonelAngus
Jul 2, 2008 08:25 PM
1peter
Sep 21, 2007 04:48 AM
