Redline Shock Proof
Old Dec 4, 2008 | 09:33 PM
iclick's Avatar
iclick
Am currently running SP Heavy in S. LA and no problems so far. Last winter I used Royal Purple 85w140 and also had no issues, but although not heated my garage rarely dips below 50 deg. even on the coldest winter nights, which for us is about 25 deg.
Frankly, I've used RP 75w90, RP 85w140, and RL SP Heavy on this bike and can't tell the difference. No difference in shifting or noise that I can ascertain. I only changed to RL because it was $4/qt. cheaper than RP from the same speed shop.
Old Dec 5, 2008 | 05:18 AM
wideopen1967's Avatar
wideopen1967
Default Grease fitting
Originally Posted by 16X9 Shooter
No.
If started in gear...etc. Might check shift linkage.
My mechanic put a fitting on my shifter so we could put anti-sieze grease in there. In your case, may have been something that got a "little stuck" in the many joints that go from shifter pegs to transmission.
It's ok after it warms up. Just really stiff before.
Old Dec 5, 2008 | 05:32 AM
StreetKing's Avatar
StreetKing
I'm still laughing on jmac's answer. I've been runinng Red Line products in my last two scoots here in Mi. Cold days just let it warm up a little.
Old Dec 5, 2008 | 07:14 AM
Lu's Avatar
Lu
I live in NJ and ride all year long (a polar bear member) and no prob with the Red Line tranny oil. Man that stuff is great huh.
Hope this helps.
Old Feb 2, 2009 | 03:56 PM
wideopen1967
Default I figured it out
If I run up through the gears 1 2 3, and back to neutral it does not stick
Old Feb 2, 2009 | 04:10 PM
iclick's Avatar
iclick
To add to what I've already posted, as someone mentioned earlier SPH has the consistency and color of Pepto Bismol, but RL claims it has the "same low fluid friction as an SAE 75W90." I surmise from that statement that is flows like a 75x90 gear oil when cold.
All this said, you aren't the only person to have had complaints about low-temperature sluggishness using RL SPH, so maybe there are issues in the HD tranny. I still haven't noticed any issues, but also can't tell any difference between SPH and Royal Purple 85w140 MaxGear, which is what I used prior to my last change to SPH. I may stick with RL because it is $4 cheaper than the RP from the same speed shop. Both are top-drawer products.
Old Feb 2, 2009 | 04:11 PM
Duke of HD's Avatar
Duke of HD
I am running the redline shock proof, took the scoot out a couple weeks ago 15deg temps and no issues. Love the stuff
Old Feb 3, 2009 | 10:38 AM
bigskyhd's Avatar
bigskyhd
Haven't had any problems with the low temp riding. Except that I go so freakin' cold by the time I get home that I can't find neutral!
Old Feb 3, 2009 | 11:23 AM
dirtdobber's Avatar
dirtdobber
Thats because you are shaking. LOL
Old Feb 3, 2009 | 11:35 AM
ezlife's Avatar
ezlife
I've run it for years, in Shovels, Evo's and Twins, never ever had a problem. Prolly the best thing you can put in your Tranny. Start the bike in neutral, and just let it warm up for about 1-2 minutes. You'll be fine.
+1, never had an issue w/RLSPH. Scoot's in unheated shed, out alot in 10s, 20s, 30s degrees. Just let her warm up a few minutes before ya hop right on n go.
Pinetop
EVO
Nov 13, 2012 01:03 PM
1flhtk4me
Sep 5, 2010 06:19 AM
shotdwg
Jun 13, 2009 10:30 PM
fatbob
May 26, 2007 02:05 AM
Dandy1
Nov 19, 2006 10:42 PM
