Help, Street Glide Console application
Old Dec 16, 2008 | 07:19 PM
fxrshog's Avatar
fxrshog
3rd Gear
Question Help, Street Glide Console application
Will an 07 Street Glide FLHX console, fit on a 06 FLHT, if I use a Roadking seat????
Thanks for any help
Old Dec 16, 2008 | 07:36 PM
Harleypingman's Avatar
Harleypingman
Yes--that's what I have been using for the past 2 years. The SG console pre-'08 is the same console (with a different decorative insert) that HD sells in the P&A catalog. I use a RK Standard solo seat. Can't be certain about the RK Custom or Classic seats since I haven't used them.
Check the P&A catalog for fitment information on the tank console to be sure.
Old Dec 16, 2008 | 07:47 PM
Sgt Mac's Avatar
Sgt Mac
+1. Friend of mine has it done, not sure how much work it was, but it is possible. I use a roadking seat on my 07FLHX and it fits well up front towards the console.
Old Dec 16, 2008 | 07:50 PM
rjmac53's Avatar
rjmac53
Nice to know...
Old Dec 16, 2008 | 08:55 PM
Harleypingman
It's a simple installation. Remove the fuel door, two screws at the front of the filler neck in the console, and the large bolt at the rear of the console.
The longer console has a gasket that attaches at the bottom--some use dabs of clear silicone to make it easier to keep it in place as the console is installed.
A new "boot" (HD part no. 61112-82A) that fits inside the console and around the filler neck is a good idea since the used one will be deformed.
Old Dec 16, 2008 | 09:25 PM
hollywoodultra's Avatar
hollywoodultra
I did this same thing on my 06 ultra, I am running the RK sundowner seat, it is easy to do, and looks nice.
Old Dec 27, 2008 | 07:26 PM
orbit's Avatar
orbit
I was wondering if you have a couple of pics of this installation. Also, how does the FLHX console attach at the rear? Is it held down with the gasket or does it have a tab at the rear in the area of the rear tank hold down bolt? Does the seat hold the end of the console in place? I was looking at the service manual and the illustration of the FLHX console is somewhat unclear.
I was thinking of using an FLHX console on my FLHTP and keeping the police saddle. I like the police seat, I don't like the cheesy plastic filler panel (seat fairing in H-D lingo).
Thanks.
Old Dec 27, 2008 | 08:20 PM
Harleypingman
Thanks.
Orbit, the SG console uses exactly the same bolt to secure the rear that your FLHTP console uses. The FLHTP console is just shorter with a flat area in front of that bolt tab. The gasket just provides a seal and some protection from metal to metal contact between the tank and console.
Your problem may be the hinge used at the front of the air ride seat. The hinge is close to the bolt that attaches the console and the SG console might interfere with the hinge unless the hinge mounts rearward of that bolt.
As for the plastic cover, it's probably easier to look at black plastic than the top of your battery, wire harnesses, etc.
Old Dec 28, 2008 | 12:11 AM
orbit's Avatar
orbit
Pingman,
Thanks for the response.
I thought the FLHX console was quite a bit longer than the FLHT console. The 'seat fairing' I referred to is the plastic filler panel that goes between the rear of the console and the front of the police saddle and is about 3 1/2" long.
How much does your RK seat ride up on the rear of the tank? 3-3 1/2"? Or is it somewhat less than that? Does the seat cover some/any of the tail of the FLHX console?
I've looked at all sorts of seat/console interface pics and I have no idea how much a seat overrides the rear of the console and/or tank (and I never really paid any attention to it when I was at various dealerships) and I got this goofy idea that the FLHX console may make the tank/seat filler area on my bike look better. Sadly, no H-D dealers are open at this hour, at least officially.
I've even thought of getting a Road King console and adapting it (fuel tank filler in place of the speedo, clock in place of the ignition switch) to suit my needs as it appears that console is longer than the FLHT console. FLHPs get by without the plastic filler panel.
I may have someone willing to fabricate a polished aluminum billet filler panel for me that would mimic the shape of the plastic filler I currently have (but be much cooler), but I think that's the high priced option right now.
Thanks again.
Old Dec 28, 2008 | 09:31 AM
Harleypingman
Orbit, if you remove the black trim piece you will see the bolt that secures the back of the console to the tank. The SG console appears longer than your console, but it uses the same bolt to secure it to the tank.
Also, if you check the HD P&A catalog, you will find the "FLHT/FLTR" trim piece, part no. 52447-96, at page 381. It permits use of RK seats (that have a shorter nose than the civilian EG and RG seats) on FLHT's and FLTR's. The black plastic piece on your bike serves a similar function, but also covers the hinge attached to the tank.
My RK seat on my bike doesn't fit over the end of the console; it just touches it as it is supposed to.
J&P or some other aftermarket vendor sells a chrome version of the HD trim piece. You could use that (with slots added to accommodate the hinge) rather than fabbing your own.
I used the HD trim piece when I removed the air seat and installed the RK Standard solo seat. This worked well for me until I decided i wanted to add the SG style console. The switch was a simple swap. Depending on whether you will need slots to accommodate the air seat hinge, the SG style console might work for you also.
Good luck with your project.
