Air Cleaner Question
Old Dec 21, 2008 | 07:59 AM
russl179's Avatar
russl179
Default Air Cleaner Question
My entire exhaust system is stock. However, I hate the cheap, ugly black plastic back plate. Can I use, say, a chrome Screamin' Eagle backplate and maintain the stock air filter and cover?
Old Dec 21, 2008 | 08:29 AM
glens's Avatar
glens
I wouldn't do that. It would necessitate an EFI remapping.
You can remove the football and after taking off the black "rubber" re-install it for a somewhat cleaner look. That is if doing so doesn't effectively "open up" the airbox (which would call for an EFI remapping).
Old Dec 21, 2008 | 05:56 PM
ngoti8tor's Avatar
ngoti8tor
I think you would be okay to do it without remapping, as long as that's your only mod. If you change your pipes later on, then you will definitely need to remap.
Old Dec 21, 2008 | 07:40 PM
molsen's Avatar
molsen
You can put a aftermarket a/c on without worry with the 2007 setup. You can use Ness big sucker, Doherty, JET performance. The last 2 has a built in velocity stack, which is good for futer mods. Once you go from there you will need to get some kind of fuel management.
Old Dec 22, 2008 | 12:50 PM
glens's Avatar
glens
There ain't no way that's true. Breathing changes on either end really should be EFI-tuned, but reasonable mufflers are somewhat "get-by-with-able" without it. The intake changes, especially if they indeed free up the breathing, definitely alter the VE values from what's in the ECU, and that primarily in areas where the mixture ain't even "closed-loop correctable".
Rondar
Feb 6, 2017 05:32 PM
user 8382390
May 30, 2015 06:48 AM
Afdharley
Screamin Eagle CVO Models
Jan 9, 2015 10:20 AM
marvo75
Mar 17, 2014 01:48 PM
FrankT
Feb 5, 2009 07:11 PM
