rush slip ons
Old Dec 26, 2008 | 03:34 PM
03duece's Avatar
03duece
Default rush slip ons
I just got done installing a pair of rush slip ons on my 09 street glide. They came off an 07 street glide and everyone said they would fit.The mounts are an half an inch off when i was installing them,is this normal???? One sits back 4 inches from the end and the other 4.5.Is one muffler supposed to go on one side or what???
Old Dec 26, 2008 | 04:24 PM
ranman469's Avatar
ranman469
i put some pipes off of a 05 on my 09 they will fit. did something move? or not together all the way??
Old Dec 26, 2008 | 04:27 PM
Point Man's Avatar
Point Man
Ya know, I thought it was me but my Rush 2" are off about the same. Didn't notice till they were installed.
What it appears to be is that the mount you're hanging the pipes from can slide forward or back; one is off just a little. That's the way it was after I evaluated it.
Take your bags off and check/measure the locations of the hanger mounts where the 2 screws go. Most likely, one or the other has slid forward or back, creating that 1/2" disparity.
Give it a try and let me know. PM me if you want with your results.
Old Dec 26, 2008 | 04:31 PM
iclick's Avatar
iclick
They should fit, and both sides are identical unless you have asymmetrical baffles (e.g., Fuel Moto). In that case the mufflers will fit but the bike will run like crap.
I don't understand what you mean by "one sits back 4 inches from the end and the other 4.5," but I assume the problem is that one is positioned about ˝" further back than the other. If you installed them and rode the bike before noticing this problem the muffler may have slowly slid backwards like my right muffler has done since I purchased the set. Try a new clamp, as HD claims their clamps are good for one installation, then become less effective or ineffective. Even when I changed clamps my right muffler still walked back, eventually until it hit the rear-most hanger position and couldn't go back any further. By that time it was quite loose and leaking. I later installed a second rubber grommet in front of the original, which prevents the muffler from moving back. I can give a better description and a photo if anyone is interested.
Old Dec 26, 2008 | 05:24 PM
03duece's Avatar
03duece
I havent rode it yet .What i was talking about is the threaded fitting in the top of the muffler.One is 4 inches from the end of the muffler and the side is 4.5 from the end.It seems like one muffler seems to slide on more than the other side.
Old Dec 26, 2008 | 07:12 PM
glens's Avatar
glens
You're saying that you push the mufflers as far onto the headpipes as you can and one goes 1/2" further forward than the other? Just pull the further-forward one back 1/2" and tighten the clamps.
Old Dec 26, 2008 | 07:20 PM
03duece's Avatar
03duece
I did that but didnt know if there was a reason why the mounting holes were offest? I evened them out and tightened them up.
Old Dec 26, 2008 | 07:33 PM
Hawgnut's Avatar
Hawgnut
Sounds like it could be a Factory error, it might have slippped in the welding jig? but I Havent owned a set of slip ons. just my two cents
Old Dec 26, 2008 | 09:23 PM
03duece's Avatar
03duece
This is my first bagger and first set of slip ons so i didnt know.
Old Dec 26, 2008 | 11:23 PM
FLoTR's Avatar
FLoTR
Muffs from 07 SG to 09 RG. Only diff is the angle on the tail end.
fatboy1340
Jan 2, 2013 04:22 PM
Storm_law
May 19, 2010 10:48 AM
FAUVDOG
May 14, 2010 11:31 PM
cdestuck
Touring Parts
Apr 29, 2010 08:30 PM
thetick1959
Exhaust System Topics
Oct 15, 2008 10:12 PM
