103" Stage II Hard Starting
Old Jan 5, 2009 | 03:56 PM
  #71
marcparnes's Avatar
marcparnes
Ok, I'll give it a try.
Thanks,
Marc
Old Jan 5, 2009 | 04:03 PM
  #72
r0de_runr's Avatar
r0de_runr
Originally Posted by copperjohn
...Try this next time you do a hot start - turn the ignition on,flip the run switch on and then hit the start button,should fire right up,I usually wait until just when the fuel pump stops pumping,try this it should work.
I don't understand.....
This is the normal sequence, unless I've been doing it all wrong
Old Jan 7, 2009 | 07:12 PM
  #73
marcparnes's Avatar
marcparnes
Default Took it for Dyno Tune Today
What a waste of time I spent 3.5 hours at Laidlaws in LA only to find out that they can't dyno tune it with the stock exhaust system in place. Seems the cat is in the way so they can't get the sniffer all the way up it's a$$. Turns out this is the first '09 with stock exhaust that they've try to do. The tech was very gracious and suggested that anything he did would be pure guess work and that it wasn't worth the money. I took his suggestion and left. He also suggested that there is a more experienced guy at another dealership and maybe I should check with him and see if he has any ideas relating to the hard starting when hot. Other than that he said I could always have compression releases installed if the problem persisted. So, now what? Nothing I guess. Geez...
Marc
Old Jan 7, 2009 | 07:55 PM
  #74
Trock's Avatar
Trock
Marc
I guess it's time to see who makes exhaust for 09's I'm putting mine on the dyno Friday. So I'll let you know what happens.
Old Jan 7, 2009 | 08:11 PM
  #75
bwickes's Avatar
bwickes
Default hard starts
1. 07 and later bikes are hard on the starters. I know of several that have been replaced.
2. These guys that say "I have x comprssion and starts just fine" are yanking your chain. Your SE255 cam has an early intake close at 25 degrees and develops more CCP than the Head Quarter builds and many others. Your CCP is around 205. The others are around 195. Big difference for the stock starter. Later closing intake cams will effectively reduce the cranking compression.
3. The stage II need compression releases for starter longevity based on what I have seen.
4. Some tuners can use the stock location O2 sensors to tune.
5. Some of the starting timing suggestions should help but I have not played with them myself.
Hope this helps.
B
Old Jan 8, 2009 | 05:10 AM
  #76
XTrooper3936's Avatar
XTrooper3936
Originally Posted by shovel52
Harley is pulling in all the CVO bikes with the 110 engines and installing compression releases and new gaskets. I imagine they have suffered lots of starters and lots of complaints about hard starting. My buddy has a 110 and has already replaced the battery and it always grunts and strains to start. It sounds like my old shovelhead. LOL. I am anxious to see what they do when his gets back. I think he took his in yesterday. We had some warm weather here in Indy. Rained like heck, but was warm.
They had a recall on CVO bikes over blown head gaskets, as well. A head gasket blew on my buddy's '06 SE Road King. They did the repair work under warranty and added compression releases to his heads. This was before the recall.
Old Jan 8, 2009 | 08:48 AM
  #77
hd0wner's Avatar
hd0wner
Marc
Marc,
Did you have them install the headers that came with the SE STG2 Kit? Those have the cat in them. I heard if you use the factory headers (no cat in them) then it will work.
Old Jan 8, 2009 | 09:28 AM
  #78
marcparnes's Avatar
marcparnes
Originally Posted by hd0wner
Marc,
Mine is a California bike and the cat is in the header pipe just south of where the front and rear pipes come together. The Stage II kit for California doesn't include any exhaust components.
The big question is if retarding the timing and/or adjusting the mixture would actually cure the hard starting problem or if it in fact needs compression releases for the long term. The cost actually works out about the same. The labor to r&r heads runs about $500 plus the labor to drill the heads estimated at $100 plus the parts which should run about $200 totaling about $800. The SEST with discount runs about $400 plus another $300 or so to have it tuned totaling about $700 not including an aftermarket exhaust in order to get rid of the cat.
The argument is that if the tuning actually fixed the starting problem I would get the side benefit of it maybe running better while installing the compression releases will for sure fix the starting problem with no other advantages. Interestingly, yesterday I rode home on the freeway in miserable traffic for about an hour and half. When I got home the motor was pretty hot which is when it normally has its problem. I waited a couple of minutes and restarted it and it cranked right over. I tried it twice with the same result. What does that mean?? I'm contemplating just waiting a bit and see how it goes and if the problem continues then probably install compression releases. At least that's the plan so far today..
I hate to say this but now I wish I had paid the extra labor and had the dealer install the kit. If I had I'd just park the thing in front of their door and let them work it out. Having had an independent do it kind of precludes any help from the dealer or HD for that matter. Lesson learned.
Marc
Old Jan 8, 2009 | 11:45 AM
  #79
r0de_runr's Avatar
r0de_runr
I suggest you find a tuner that will tune using wide band 02 sensors and any of the available tuning devices that allow for AFR and spark adjustments.
I know of such a tuner in Texas, and it was worth the ride and motel rooms to have him tune my 103 inch 09 with stock pipes..
Purrs like a kitten.
Old Jan 8, 2009 | 12:38 PM
  #80
EG Ultra Classic's Avatar
EG Ultra Classic
Mine has a couple of times fired back when cranking hot, Like when I kill it and quickly restart, and if you keep on the starter and push the high pressure charge thru, it will then start normally. So far my starter has had enough power to do that. Not sure if that pressure charge shortens the starter's life when the momentary extra overload hits the starter, but so far it will pull thru it. Like I said it has happened only a couple of times, all the rest of the time it starts normally, just don't let off the button until it has completely started as an early starter release could mistakenly be a kick back , not a complete start, and cause a bit of a drive mechanism backwards spinning once you start button.
If it ever does cost me a starter, I am dam sure replacing with the heavy duty starter and also pay the dealer to get the compression releases installed. I hate a bike that won't start. But I love my big bore 103". The only way in time I am going is bigger bore. No substitute for cubic inches in a slow speed tractor.
