Speakers installed
Old Jan 6, 2009 | 07:42 PM
pirateheadman's Avatar
pirateheadman
Default How do they sound?
Originally Posted by cfoster80
Installed new speakers on my SG this past weekend. Havent riden down the road yet and listened to them but was in the garage playing around they ROCK.
Sooo... have you road tested them yet? You did your research and you are right about the "marine grade" speakers. I don't think there's anything wrong with "car" speakers on the scoot unless you shoot a jet of water into them when your washing it. Even then, they have fiberglass cones and rubber surrounds. I'm sure car doors get a bit of moisture in there when you roll down a wet window!
Old Jan 6, 2009 | 08:38 PM
GasCan's Avatar
GasCan
You DO NOT need marine grade speakers at all. All car audio speakers are water resistant to an extent and almost all of them now days have a polycarbonate , graphite, or titanium coated cone and include a rubber seal. Worry not...just use them.
Old Jan 6, 2009 | 08:55 PM
BuckBaker's Avatar
BuckBaker
I did the HogTunes sounded ok doing 60 , then I swithched to the Hawg Wired with amp . Now that's the way to go !!!!!!!!!!!!
Old Jan 6, 2009 | 10:50 PM
bikergeoff's Avatar
bikergeoff
No need for marine grade in the fairing, but I installed some JBL marine grade speakers in my lowers, since they are not as protected from the elements. They rock!
Old Jan 7, 2009 | 06:56 AM
JustDennis's Avatar
JustDennis
Originally Posted by IslandGlide
... I switched out to HogTunes, which I feel are better, but still by no means great. I think the only way to be happy will be to install and amp, but I have yet to allot $500 for an amp and speaker package...
You can add the hogtunes amp for a little over $200 with the speakers you have now.
Old Jan 7, 2009 | 12:01 PM
IslandGlide's Avatar
IslandGlide
Thanks JustDennis
I can't seem to find just the amp on their website, so I sent them an email to see if it is available
Old Jan 7, 2009 | 08:27 PM
quint's Avatar
quint
Cfoster
I installed the Infinity Kappas on my Street Glide over Christmas. Aside from losing a couple of the fairing Torx bolts in the lower fork triple-tree shroud (and then having to dismantle all that to get them back out), the whole thing only took a couple of hours. A few comments:
1. For sixty-five bucks, the best sound improvement you'll ever get
2. Don't worry about marine grade - the speaker cones are are woven glass fiber, and it would take torrential rain and gale force winds blowing SIDEWAYS to get any real water in through the grill
3. The standard HK head unit will clip the signal when you crank it up too loud - a sound wave is naturally a sine wave shape (gentle undulations). When the amp is stretched, it turns the sound wave more square, clipping the humps and bumps, making it distorted. A more powerful amp is the solution to this - for a given sound volume, it won't be pushed as much.
4. The Kappa has the ability to wind up or down the tweeter levels - since high frequency sounds are unidirectional and low frequencies are omni directional, I'd suggest winding the tweeter right down. With the speakers in a car door, you need a brighter sound because the high frequencies do not have a direct pathway to your ear. With speakers pointing right at your face, you want the tweeter levels at their lowest.
5. A 5.25" driver is never going to give concert hall bass, but the Kappas are a BIG improvement over the standard crappy chinese speakers that HD install in the fairing.
As I said before, $65 shipped is a big saving over the original $150 MSRP and they are a quality sounding speaker. I should also add that I have a 9.5" windshield and I wear a skid lid, so my ears aren't covered.
Old Jan 7, 2009 | 08:31 PM
D34's Avatar
D34
I installed J&M speakers and they sound fine............for now.
Old Jan 8, 2009 | 10:46 AM
cfoster80's Avatar
cfoster80
Originally Posted by quint
Cfoster
Well put, that was exactly my piont when i was told i needed marine grade speakers. My original post was just to inform everyone that i liked speakers so far compare to the JUNK HD stock ones.
Thanks for the pionters on turning the tweeters down. I turned them down when i installed them thinking without an amp running them it may be over kill.
Thanks
scumBAGGER
Audio Systems
Jan 31, 2015 11:07 AM
user 6292802
Touring Parts
Feb 2, 2014 01:15 PM
irish2
Feb 23, 2010 04:11 PM
SeniorChief56
Feb 16, 2010 12:20 AM
Psychosis
Dec 28, 2009 08:50 PM
