Need IDS exploded view (or help)
Old Jan 11, 2009 | 05:05 PM
stro1965's Avatar
stro1965
Default Need IDS exploded view (or help)
I'm reassembling my rear wheel and hit a roadblock. My bike is an '07 with dealer added IDS, so my service manual doesn't help. I have 2 spacers. One obviously goes inboard of the braker caliper, the other inside the IDS between the hub and the sprocket. I managed to mix them up and I'm not sure which is which. One is slightly thicker than the other. HELP???!!!
Old Jan 11, 2009 | 05:11 PM
jimsuver's Avatar
jimsuver
The thick one goes inside and the thin one goes on the left. The brake is the spacer on the right. That is for my 07 EGS anyway.
Old Jan 11, 2009 | 05:15 PM
stro1965's Avatar
stro1965
Are you sure there isn't a spacer between your right side wheel bearing and the brake caliper?
I have what appears to be a thick washer, which I believe is the outer IDS spacer. I also have 2 thicker spacers, 1 is obviously thicker than the other.
They look to be maybe 5/16" and 3/8" thick I THINK the thicker one goes inside the IDS but I'm not sure.
jimsuver's Avatar
jimsuver
There is also a spacer from the wheel to the brake and it is thicker than the left one.
Old Jan 11, 2009 | 06:19 PM
stro1965's Avatar
stro1965
I figured it out (I think). The thicker of the 2 "thick" spacers goes inside the IDS, between the hub and the sprocket. When I put the thinner one in and put the sprocket on there was considerable play, not so with the thicker one. Hope it's right because it's all back together now! I'm pretty sure it's good though, it all looks to be lined up right and the wheel rolls good with no binding.
Old Jan 11, 2009 | 06:41 PM
Hog Yild's Avatar
Hog Yild
I had mine apart a few weeks ago and measured the thicknesses of the spacers.
Looking from the back of the bike, The outer most left spacer is #11844 and is .135" thick. The next spacer that goes between the IDS sprocket and the part that is bolted to the wheel is #11846 and is .556" thick. on the right side there is a spacer between the wheel bearing and the brake caliper mount, this spacer is #41084-02A and is .471" thick and lastly is the brake caliper mount itself which is 1.185" thick.
I hope this will help.
Old Jan 11, 2009 | 06:43 PM
stro1965's Avatar
stro1965
That's exactly what I was looking for and it's good news cause that's the way I installed them! Now where were you 2 hours ago?? LOL
Old Jan 11, 2009 | 06:47 PM
WVULTRA's Avatar
WVULTRA
stro:
I was shocked to see your post as I went through the same thing last week! Had the wheel off, seperated the IDS to check the rubber isolators, and after cleaning things up ended up with two very similar spacers and not sure where they went!
After indulging the help of a good friend, got the measurements for both spacers and as you've figured out the wider of the two (p/n 11486) goes in the IDS. It's ~.545" wide and the other that goes next to the rotor is just under 1/2". I ended up marking the wider one with a perm marker prior to reinstalling so I wouldn't have a major brain fade like this agian.
Old Jan 11, 2009 | 06:51 PM
Hog Yild's Avatar
Hog Yild
Out working on my bike as well, only the front end
Old Jan 11, 2009 | 06:52 PM
WVULTRA's Avatar
WVULTRA
And I see Hog Yild gave you great info while I was typing.
Hog: I'll save your dimensions for future use.
Thanks!!
