95 build
Old Jan 16, 2009 | 07:47 AM
yota's Avatar
yota
Default 95 build
I am just tweaking a 95 build stage 2 on 05 ultra. Can anyone give pros and cons to this set up..Being done by dealer and will be using the 95 kit sold by them with 204 cams and adjustable rods. I am planning to leave the old set up for cam chains as I can not clear the gear drives with the liittle lady. I have HD screain eagle pipes on it now with stock header set up..Is the 204 cam the good choice or anything better I should look into.
Old Jan 16, 2009 | 08:24 AM
FXSTDSE2's Avatar
FXSTDSE2
The 95 stage II comes with 203 cams? My SE Deuce has the stage II installed from the factory. Compared to a stock 88 it is a very noticeable difference. Runs well as low as 1800 and has plenty of pull @ 2400 and easily hits the rev limiter at 5500. It was rated at 91ft-lds @3500 but with the addition of the propipe it is a little stronger throughout the entire rpm rang. With either the 203 or 204 cam, adjustable rods aren't needed unless that is your choice. I would run a set of perfect fit or keep the stock ones.
Old Jan 16, 2009 | 08:33 AM
mattman22033's Avatar
mattman22033
I have the SE stage II w/203 cams in my RG. It was on the bike when I bought it. I switched to duals w/Rhinehart slip-ons and added a PCIII. The power level is fine for me.
Old Jan 20, 2009 | 07:55 AM
yota's Avatar
yota
Default Talk is that the cams are 204..not 203
I am not up on engine builds...Whats the difference in 204 versus 203 cams...Also the talk is adjustable push rods...Again the differences...Should I go with the suggested build which is 204 and adjustables..???
sskimber
May 30, 2016 10:17 AM
butch patrick
Dec 5, 2012 01:32 PM
Dale M Ludwig
Exhaust System Topics
Jan 28, 2012 10:55 AM
1sweetglide08
Apr 21, 2011 12:10 AM
beary
Aug 19, 2010 06:13 AM
