TTS -VS- Power Commander III.
Most of what is out there can come preprogramed so you do not need a Dyno unless you have done some really major engine mods. Alot of people told me I needed to have a PC111 dyned, the reality is that there are plenty of maps out there that can be downloaded and installed. The PC111 can be easily installed by anyone as the ssam with the F1200r which I was also looking at. I was looking between the Fi200r, the PC111 USB and the TTS Mastertune. The Fi2000 and PC111 were close in price the master tune was slightly more.
My end choice was the PC111 A lot of people were trying to sell me on the fact that I needed to dyno the PC111 and I am sure it probably might slightly improve what I have now I but i know it would not be by much for the money I would have to spend on the Dyno.
I would contact Jamie at Fuel Moto as they sell the PC111 and the TTS and tell them what you are trying to achieve. The dealer did feed you a bunch of BS.
Again there is tons of comments on both here in the forum, good luck!
A year later I did the 95" cams, gear drive and had it dyno'd again. Three years and a great indy that knew how to use the dyno and I am still very happy with the PCIII results.
ANY bike from stock to highly modified benefits from a precise dyno tune performed by an experienced tech.
NOTE: Don't waste cash on Auto Tuners, DFO's or HD downloads!
As you said, the dealer is out of touch and simply wrong. A PCIII or PCV purchased from Fuel Moto does not require a dyno tune, as Jamie has many maps for almost any configuration imaginable, and they are accurate. The really trick setup is the PCIII or PCV with Dyno-tuned Jackpot mufflers and AC.
The best dyno tuner in the world is still working with a SIMULATOR. The TTS Mastertune works with reality. And really good dyno tuners are far outnumbered by the hacks.
The folks who claim that you can use a map from Jamie (or anyone else, for that matter) and get as good a tune are incorrect. There are too many variables from bike to bike. OTOH, a map from Jamie that is CLOSE beats the heck out of a poorly done dyno tune.
You pay your money and you make your choice. If you have access to a laptop and a little time you can get a great tune with the TTS Mastertune without having to find (and pay) a good dyno operator. As an added advantage, you can retune the bike whenever you make a change, and as it wears over the years.
If you don't want to go with a Mastertune, then it's simple - ask around and find out if you have access to a good dyno tuner. If not, call Jamie. If you do, talk to the dyno operator and see what they prefer - and go with that. Dyno tunes have a whole lot more to do with the operator than the hardware.
First a PCIII, then a Thundermax with Autotune, and finally a TTS.
I an not saying that you can't get satisfactory results from a PCIII, but I had to get mine dynoed before I thought it ran correctly. And even then, the mileage was not good. Any Power Commander is a piggy back system. The PCIII eliminated the O2 sensors.
Then I tried the Thundermax with autotune. It worked fairly well, but I fought timing issues and finally gave up. Remember, the autotune function only auto tunes the AFR, not the timing. I was still getting poor fuel mileage. The Tmax is a replacement of the OEM ECM and O2 sensors.
The TTS finally got the bike where I wanted it. The bike runs great and the mileage is excellent. It is nearly 10 MPG better than with the dyno tuned PCIII. The TTS is a tuner. You attach it, program the OEM ECM, and remove it. I got great results from the Vtune program that came with the unit. As someone mentioned, you can use the Vtune with a laptop to tune your own bike without a dyno. It worked perfectly for me.
In my opinion, you would be crazy to remove the factory O2 sensor system from a 2007 and up bike.
The bottom line.........
I would use a dynoed PCIII or PCV(new version) for a 2006 or earlier fuel injected bike, but I would stick with a SERT or TTS for O2 equipped 2007 and later fuel injected Harley.
Just my $0.02.
