TTS -VS- Power Commander III.
I don't pretend to know enough to answer all your questions on how the TTS works, but after talking to experts on both coasts I believe it works. I was unhappy with a dyno-tune, and used the TTS-generated map to correct the issues. I then took the bike back to the same tuner for evaluation, and he was (1) pissed that I had redone the tune myself and (2) unable to find any real issues with the new tune once he put it on the dyno. He checked the AFR at WOT and found it to be ideal. He desperately wanted to show me where I'd screwed up - but couldn't. The bike runs great.
The TTS is NOT for everybody. A computer-literate person with access to a laptop can get great results with it. I was able to purchase the TTS and cables to do BOTH our bikes for under $700 - and had I known, I could have saved time and money and tuned them myself without a dyno. I suspect that you are getting similar results with the PC-V, but it cost more (with the auto-tune) and you still have another device to mount and connect. It appears that you really like the PC-V, and enjoy working with it - so more power to you! I suspect you would enjoy the TTS, as well, as you like to be able to really delve into the programming. I just wanted to get my bike to run right, and I did. If I make changes to the bike in the future, I'll be able to retune it as needed.
The PCV-AT is more expensive than TTS at around $600 ($300 each for PCV and AT), but it isn't locked into one bike. The AT can be moved from bike to bike, but the PCV only so if the connectors and pin assignments are the same. For example a PCV for an '09 Softail will fit any FLH from 2002-2007 and all 2002-09 Dynas and Softails, but not '08 or '09 FLH's.
In fact, a trick idea for those with more than one bike would be to buy one PCV per bike with only one AT module. You could move the AT from one bike to the next, writing the trims to a base map for each which would then be that bike's new map based on real-world variables. In that case you'd be out about $450 each for two bikes, $400 for three, etc. The quandary would be which bike would ultimately get the AT module.
