Premium Oil Cooler Kit
Old Jan 24, 2009 | 02:25 PM
davlyo's Avatar
davlyo
Post Premium Oil Cooler Kit
I have three questions pertaining to the referenced Premium Oil Cooler Kit (GMA Part No 26155-07).
First: any insight?
Second: will it fit seamlessly with a Chrome Voltage Regulator (GMA Part No 74622-06) –or actually –will the Chrome Voltage Regulator fit seamlessly with the Premium Oil Cooler?
Third: the kits come with two oil line hoses –any insight as to replacement braided lines –perhaps made by Russell or another? As many of you know it is absolutely critical that one also purchase a braided line when installing the HD Oil Pressure gauge.
Thanks HDForums members –my Harley wouldn’t be what it is without the knowledge and insight I have got from this forum.
Old Jan 24, 2009 | 02:41 PM
cruise_carter's Avatar
cruise_carter
I have the Jagg 10 row.
Works great, the chrome voltage regulator cover works with it, used the supplied lines. No need for braided lines.
No issues and well worth the money.
Can't answer about the HD premium oil cooler kit.
Old Jan 24, 2009 | 02:45 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
over two years and only 14 posts , wow
Old Jan 24, 2009 | 02:52 PM
IBHarley's Avatar
IBHarley
I put one on my 08 Ultra it will fit with the chrome regulator but not the chrome cover I also added the PC cooling fans behind the cooler for when Im in stop and go traffic as for braided lines I am not aware of any other than covering them yourself with one of the kits but they are probably out there ,as for does it work well its still hot but Im in south florida so its always hot any extra cooling is worth it
Old Jan 24, 2009 | 03:09 PM
captjon37's Avatar
captjon37
Is there a minimum post per year?
I installed the HD oil cooler and if you can change your own oil you can install it. It was very easy. No need in changing the hoses unless you just want the look. I heard you need to do a little dremel work to get the chrome reg cover to work but not sure as i just did not want that piece.
Old Jan 24, 2009 | 04:20 PM
UALCapt's Avatar
UALCapt
To IBHarley ... What are the PC cooling fans that you mention? Thanks!
VTwinJaxFL
Aug 11, 2011 09:03 AM
watercop
Jul 24, 2010 06:58 AM
leeinmemphis
Dec 24, 2009 12:00 PM
rkc9999
Apr 28, 2008 12:45 PM
Snort
Jun 3, 2007 12:14 PM
