Clutch lever action not real smooth
Old Jan 29, 2009 | 11:12 AM
BlackFLHR's Avatar
BlackFLHR
Default Clutch lever action not real smooth
2009 Road King Classic, 2500 miles...
The movement of the clutch lever doesn't seem to be very smooth. I mainly notice on my morning ride to work. Kinda feels like it very slightly sticks a little when releasing the clutch. The actual clutch itself is fine, no slippage or anything like that. I've looked at the cable, and there's no binding anywhere.
Would the cable need to be lubed with this few miles? And if so, what's the easiest way for a home mechanic to do it (without buying one of those special cable lube tools)? Will simple 3n1 oil work?
Old Jan 29, 2009 | 11:37 AM
skydoc's Avatar
skydoc
DRI SLIDE click here
Old Jan 29, 2009 | 11:47 AM
dgriffith's Avatar
dgriffith
Go into you local bike shop and get an oil pen. It has a clear plastic body with a metal needle end on it, so it will fit into the end of the clutch cable. They are about $5 and they work wonders on the clutch and throttle cables. That is what they are made for. May I suggest , get a service book. It will make your life with your bike a lot easier. It will answer all your Questions on how to do many things. From a simple bulb replacement to .............
Old Jan 29, 2009 | 12:03 PM
rrsjs5's Avatar
rrsjs5
Originally Posted by skydoc
A few bucks cheaper,same stuff,works wonders..
https://www.storesonline.com/site/696296/product/T1247
Old Jan 29, 2009 | 12:18 PM
BlackFLHR's Avatar
BlackFLHR
Thanks for the product recommendations... But is this common for a new bike with 2500 miles on it, to need cable lubing already? Or is it just the nature of the beast?
Old Jan 29, 2009 | 12:23 PM
stu07hd's Avatar
stu07hd
I am not suprised that the cable may need lubed after 2500 miles. I use cable lube on mine at every service (3000 miles) and am always suprised how much better they feel afterwards. Did you have the 1000 mile service done or complete it yourself? Who knows, maybe yours got out the factory door with un-lubed or lightly lubed cables.
Old Jan 29, 2009 | 02:40 PM
oinker02's Avatar
oinker02
2500 miles?.....you are due for full clutch adjustment-both primary and cable end...you can do it yourself if you have torx27 bit and a couple of open end wrenches....you don't need a book cause it's on the web if you search.
Place bike on jiffy stand and pull primary cover using torx27 bit, it won't leak primary oil unless it's too full to start with.....adjust clutch release inside primary using open end wrench and allen wrench, then adjust cable by the book....10 minutes and you are done.
This is good time to remove cable from upper lever and force lube down inside....too much is better and simply wipes off.
If catchy actions persists, then demand dealer fix it under warranty cause cable might be frayed.
You are correct that clutch should travel freely and not feel like yours....see if you can fix it yourself first.....your scoot and you need to bond, so get her oil under your nails.
Old Jan 29, 2009 | 02:52 PM
beary's Avatar
beary
I wouldn't have thought 2500 miles, but the Dryslide is a cheap way to find out if that is your problem or if it is something more serious.
Beary
Old Jan 29, 2009 | 03:06 PM
hawg08's Avatar
hawg08
Mine wasn't smooth either and even made a little squeaking noise with 2700 miles on the clock. I held the clutch lever in and dabbed a little silicone grease on the bottom and top of the lever where it goes into the housing, pulled it a few times and it was fixed; no squeak and easier to pull. I've never had to do this on any of my other Harleys so this must be some kind of "improvement" that was made to the later models.
Old Jan 29, 2009 | 03:07 PM
oinker02's Avatar
oinker02
Beary
2500 miles is 5 times beyond first primary side clutch adjustment......Yep, it needs done by the first 500 miles and rather often afterwards depending on how you ride.
Don't get me wrong, never should a new clutch exibit the problems he describes, but first he should perform the adjustment and lube, then see if it goes away.
