12v trigger for amp
Old Jan 30, 2009 | 01:55 PM
3/4 life crisis's Avatar
3/4 life crisis
Default 12v trigger for amp
Hi all,
08 Street Glide. I have a set of Kenwood Excelon 5 1/4" speakers and an Alpine 3522S sitting around for several years, trying to put them in good use.
Question: where should I tap in the 12v trigger behind the fairing so the amp (hence stereo) will turn on in Acc. position as well instead of just IGN.?
Thanks in advance, ride safe.....
Old Jan 30, 2009 | 04:41 PM
3/4 life crisis
I think I found a way. How about the cig. lighter hot wire? Couldn't remember if it's ACC. hot as well as IGN. hot.
Will find out tonite when I get home......
Old Jan 30, 2009 | 05:30 PM
lasvegasrick's Avatar
lasvegasrick
Talking
the spear wire on the head lite wire will work
Old Jan 30, 2009 | 10:11 PM
3/4 life crisis
Thanks LVRick. The pigtail from the headlight as well as the cig. lighter power wire will work. Both IGN. and ACC.
Now see if I can use a fiberglass fishrod to run power wire back to battery so I don't have to remove gas tank Will get to it next couple of days.
Old Jan 30, 2009 | 10:17 PM
09StreetGlider's Avatar
09StreetGlider
fishing rod is a good idea....i ended up buying a wire fishing reel for use fishing wires through walls. If the fishing rod doesn't work, go to lowes, ace, or home depot and pick up one of those before removing tank.
Old Jan 31, 2009 | 06:57 AM
Sincecrazy's Avatar
Sincecrazy
I used a piece of 10awg wire. It pushed through pretty easily.
vhmike73
Audio Systems
Oct 17, 2014 11:38 AM
DeneFXDWG
Audio Systems
Apr 15, 2014 11:02 AM
2067
Jun 10, 2012 08:18 PM
EricFLTRU
May 25, 2011 01:50 PM
Pumba11
Mar 27, 2009 09:24 AM
