J&p cycles smoked tailight lens melting
Old Feb 5, 2009 | 09:19 AM
rome304's Avatar
rome304
Default J&p cycles smoked tailight lens melting
anyone have a problem with the smoked tailight lens from j&p melting had mine about a month and this morning i noticed in middle of lens melted circle i'm using a led bulb any help appreciated.
Old Feb 5, 2009 | 10:22 AM
Ca.Fatlad's Avatar
Ca.Fatlad
Question
Mine did the same thing on my 04/Fat Boy, took it off and put red one back on.:
Old Feb 5, 2009 | 11:22 AM
roadking 3239's Avatar
roadking 3239
Default Smoked lay down lens
I just installed a smoked laydown on my Road King with a iridium bulb. I sure hope I don't have that problem, I'll be pissed! Won't know for a couple months cause there's still 10" of the white stuff on the ground. Will keep you posted
Old Feb 5, 2009 | 11:27 AM
rome304's Avatar
rome304
is that the type of bulb that comes with the kury smoke lens set up?
Old Feb 5, 2009 | 11:56 AM
yoseppi's Avatar
yoseppi
Those smoked laydown lenses are just cheapie plastic anyway. Hope nobody paid too much for theirs.
Old Feb 5, 2009 | 12:06 PM
gmc's Avatar
gmc
Most laydn need LED board which they should tell you or update their book. I was going to order one fr DK and they warned me that so I went w ridetimetechnology for complete pkg. I woud send it back.
Old Feb 5, 2009 | 12:24 PM
rome304's Avatar
rome304
contacted frank at j&p cycles he first said i can only use amber i explained it was the tailight he said i may need a shorter bulb wanted to get info before they sent me out new cover the led bulb is longer than stock red replacement and may be to close to lense hopefully j&p will stand behind there products? very happy with the look until i saw the melting.
Old Feb 5, 2009 | 04:39 PM
skratch's Avatar
skratch
i'm curious about the heat that the leds are putting out. leds are supposed to be very low current, so there shouldn't be enough heat generated to melt a lens..... in fact, most of the laydown lenses that i have seen say that you have to use a led setup due to the high heat generated by the incandescent bulb.....
Old Feb 5, 2009 | 05:10 PM
rome304's Avatar
rome304
the laydown lenses are about a 1-1/2" shorter than stock lenses so maybe being that close will cause it have'nt heard back from j&p cycles yet.
Old Feb 5, 2009 | 06:18 PM
garyhendley's Avatar
garyhendley
i have the j&p smoked lay down lens and the led equal to a 1157 i think
but i have no melting issues-ride safe
