Oil Change Procedure
Old Feb 9, 2009 | 12:21 AM
Westminster's Avatar
Westminster
Default Oil Change Procedure
Taking encouragement from many comments on the forum, I bought the manual and figured I could at least change my oil. With experienced friend helping, no problems but I do have a couple questions on Primary Chain lube. First, the manual directs to disconnect the battery before proceeding. Is this really necessary? I just used the kill switch to insure the engine wouldn’t inadvertently jump start while advancing rear wheel to check the chain tension. What don’t I understand about this precaution?
Second, when it comes to filling the primary chain reservoir the manual stipulates pouring oil in through the clutch inspection cover. It seems like it would be a lot easier to pour oil in through primary chain inspection cover opening. In fact, my clutch assembly sits closer to the edge of the casing making it very difficult to add oil. There is not enough of a lip on the edge of the opening to pour directly so we had to do a make-shift conduit from oil bottle. Is there a reason I can’t change primary chain oil by pouring oil in through primary chain cover opening?
Thanks for any tips or insights.
Old Feb 9, 2009 | 12:40 AM
OhioSkully's Avatar
OhioSkully
First, harley will tell you to disconnect the battery for about every instruction they give you its a cover there *** direction in case something bad happens. No need to do it.
And yes most everyone fills there oil thru the inspection cover on the bikes that have them.
glad to see your doing it after the first time it gets easy.
Old Feb 9, 2009 | 01:39 AM
HEMSPLT's Avatar
HEMSPLT
What he said. Disconnecting the battery keeps the lawyers happy. Be smart about it and disconnect it if you are doing electrical work. I don't see any way the engine can jump with the ignition switch off.
Pour your primary oil in whichever hole happens to be open. The later models, like my '08 Road Glide don't have the primary chain inspection cover so you're stuck using the clutch hole.
If you have friends to back you up don't be afraid to do anything on your bike. Harleys are pretty straight forward with their design, which makes them easy to work on. The more you do the smarter you'll get but more importantly you'll save a ton of money on labor. Use the money you save on labor to buy tools and accessories.
Good luck.
Old Feb 9, 2009 | 04:44 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Your approach is right on target. Go with it.
Old Feb 9, 2009 | 09:09 PM
Westminster
Thanks my friends for your replies and encouragement.
Old Feb 9, 2009 | 10:15 PM
iclick's Avatar
iclick
No. It's lawyerspeak with no practical aspect.
'07's and above don't have the inspection cover, so the Derby cover is the only alternative. But I would still use the Derby cover in your case since it doesn't use a messy paper gasket. Maybe newer bikes are different, but my '96 RK used a paper gasket for the chain inspection cover and it was a pain to change since you had to scrape it off both the cover and outer primary cover. My '07's clutch basket is also very close to the outer primary cover, but it also has an indentation that allows you to insert a funnel. I'm not sure if yours has one or not.
Old Feb 10, 2009 | 05:47 AM
The Old Man's Avatar
The Old Man
I think think the owner manuel says to fill the primary up to and just over the edge of the clutch plates, which you can just see in the funnel cut out with the derby cover removed. If you have the other opening at the top of the case you will need to measure the oil. Other then that really simple.
Old Feb 10, 2009 | 06:02 AM
Frankie-FLHXI's Avatar
Frankie-FLHXI
going to do mine this year for the first time! oh boy
Old Feb 10, 2009 | 06:25 AM
Peppa1's Avatar
Peppa1
If you have the inspection cover use it. You are already in there checking the adjustment on the primary chain anyway !!!
Old Feb 10, 2009 | 07:45 AM
dog155's Avatar
dog155
Some people at one time or another have actually drained the oil and absent mindedly driven off forgetting they did so,thus the dissconect battery.Believe it or not!fill primary through chain inspection,it is much less hassle.Good Luck
