pc111 throttle set
Old Feb 9, 2009 | 08:28 PM
stglideblk's Avatar
stglideblk
Default pc111 throttle set
Yes i did a search, but still having problems. It is programmed from Jamie, but when i put the disc in the laptop all i get is an infomercial. Do i need the 9volt if the pc111 is on the bike? We plugged the pc111 into laptop and nothing happened. Before you guys rip my head off, i am a baby boomer and not electronically savy.
Old Feb 9, 2009 | 08:32 PM
THABULL's Avatar
THABULL
Got the bike running??
Old Feb 9, 2009 | 08:34 PM
stglideblk's Avatar
stglideblk
bike is running
Old Feb 9, 2009 | 08:38 PM
Badbagger's Avatar
Badbagger
Here ya go... just did the install yesterday: (Bike is NOT running)
Install the PC software to a notebook computer, connect the PCIII to the computer via USB, and launch the software. Under "Power Commander Tools" click on "Set Throttle Position." Connect the 9V adapter in the kit to the PCIII and turn on the ignition without starting the engine. Without moving the throttle click on "Reset" and after a few seconds twist the throttle to 100% until the number under "Open" settles in a second or two. Close that window and the throttle and look in the main window for "% Throttle," which should say "0%". Twist the throttle again to 100% and it should show accordingly in the digital readout. If not, repeat the procedure. If you can only get 99% or so instead of 100% that's close enough. Turn everything off, remove the USB cable, replace the side cover and saddlebag, and you're ready to roll.
Old Feb 9, 2009 | 08:45 PM
stglideblk's Avatar
stglideblk
Thanks Badbagger, but i am not getting anything to show on the laptop. If the program would come up i think i could get it done.
Old Feb 9, 2009 | 08:50 PM
Badbagger's Avatar
Badbagger
Plug everything in good and tight to make sure the link is good. Make SURE you've got a NEW battery.. it eats batteries.. then start the software up and follow the directions I posted.
Old Feb 9, 2009 | 09:04 PM
Badbagger's Avatar
Badbagger
Try to reinstall the software also if need be.
Old Feb 10, 2009 | 07:15 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Feel free to contact us and we can walk you thru it over the phone. Here is video tutorial you may also find helpful http://fuelmotousa.com/SetThrottle.swf
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Feb 10, 2009 | 07:54 PM
LH's Avatar
LH
Jamie, do you feel the TBW systems really need to set the throttle ? What is the adverse if it isn't done ?
Old Feb 10, 2009 | 08:15 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
With the 08-09 DBW bikes it is a good idea to check the closed throttle position with the bike at operating temp, but we find that on these models the TPS is very stable and in most applications does not to be reset. Also note that on the DBW wire bikes the open throttle position can only be set under full load such as on a dyno.
AFblacksheep
Jan 26, 2010 12:23 PM
JoeSwiatek
May 16, 2008 12:54 PM
roadrider
Mar 9, 2008 04:59 PM
ezlife
May 12, 2007 11:34 PM
UltraScoot
Apr 22, 2006 03:57 PM
