Installing an Amplifier into a fairing
Old Feb 22, 2009 | 09:37 AM
  #31
ZEALOUS_DRAGON's Avatar
ZEALOUS_DRAGON
Post
Originally Posted by turbo38sfi
ZD:
What do you ride now, do you have the stock HK radio?
2009 Street Glide - Sony Head Unit CDX-GT81UW 208W- Biketronics install kit with handlebar control - Polk Audio DB6501 300W 6.5" Component speakers in fairing - Polk Audio DB650 180W 6.5" 2-way spekers in the lower fairings
Old Feb 22, 2009 | 10:16 AM
  #32
dirtdobber's Avatar
dirtdobber
You get what you pay for
* Total Harmonic Distortion: Less than 0.1%
* Signal to Noise Ratio: More than 90 dB
* Frequency Response: 20 ~ 20k Hz
* Output: 75 Watt Max x 2CH @ 0.2% THD / 25 Watt RMS (4 ohm) x 2CH @ 0.05% THD
* Dimensions (in.): 1.5" x 2.5" x 4"
* Power Draw: 2 Amps
* Power: 150 Watts
* Designed for 4 ohm speakers - use with other ohm speakers may void warranties and damage your speakers
* Two-year warranty
Old Feb 22, 2009 | 10:24 AM
  #33
ZEALOUS_DRAGON
Question
* Power: 150 Watts
* Two-year warranty
Are these considered "bad" numbers? What is the ARC specifications?
What is an ARC amp going for these days anyways?
Old Feb 22, 2009 | 11:58 AM
  #34
blueflht's Avatar
blueflht
go to firecap501 website for prices and specs. what it appears is at 4 ohm you are only getting 25 watts root mean square. (rms) factory radio is around 11 watts rms 90 db sig to noise ratio is high also the amp you are looking at doesnt say what class but with the size gage wire it may be a d class amp runs very hot
Old Feb 22, 2009 | 02:49 PM
  #35
ZEALOUS_DRAGON
Question
Where do you find firecap501's website?
Old Feb 22, 2009 | 03:38 PM
  #36
speedkillsu2's Avatar
speedkillsu2
FireCaps website
http://www.mike5959.com/myhogrocks/
He's a great guy to deal with.
Old Feb 23, 2009 | 02:26 AM
  #37
sublime_ac's Avatar
sublime_ac
Originally Posted by GasCan
One of these days we're gonna hear of some guy losing his bagger in a fire where the internal wiring ignites and starts a fire in the fairing. I don't think most people know how hot some of the class A/B car amps can get. Have you ever seen what happens to one when they get real hot? Seriously!
Save you money and get something that runs cool if you're gonna stick it in the fairing.
I am not sure how the Arc mini is a class A/B, but it must be one of the most efficient class A/B's ever made as it does not get hot... You can crank it for an hour and touch it with your bare hand no problem..
Old Feb 23, 2009 | 06:50 AM
  #38
Goodwrench1967's Avatar
Goodwrench1967
I really dont understand why people ask questions and get all defensive when they dont get the answer they want.. if you want a cheap amp go buy it. I use my radio about 20 percent of the time. I would rather hear the sound of my bike.... but thats just me. I have had lots of experience with car audio and you really just cant substitute quality for price and expect the same results. I would think that any of the systems that are designed to be direct plug in upgrades specifically made for your application would be well worth the cost if you are expecting to have a high quality result. guess thats why i just read and dont post much....
Old Feb 23, 2009 | 07:25 PM
  #39
perch73's Avatar
perch73
3rd Gear
i did alot of searching just as you did for an amp that was a little cheaper and would fit in the fairing. i ended up getting the MB Quart RAB250. with an aftermarket head unit it will fit and i only paid $95 for it. so far it has been flawless in Texas heat. i used a Sony head unit with ipod controls (i just let the cable hang out from underneath the fairing) i put some velcro on the back of the ipod and on the lower part of the fairing and just plug the ipod to the cable and stick it to the fairing. i bought the Biketronics kit and the hand controls work for changing songs on the ipod. i can go through different menus using the head unit controls, never have to mess with the ipod itself. the amp is pushing 2 alpine 5.25 R series speakers and the sound is loud and clear. couldn't be happier
Old Feb 23, 2009 | 07:53 PM
  #40
customsoftail200's Avatar
customsoftail200
Hey Perch, where did you mount the amp??
