My spherical rod end shifter upgrade.
The sperical rod ends I used were the HD part number 33871-85B. These have the same thread as the original shifter rod so I didn't have to replace that. The rod ends are a bit longer than the stock fitting, so I left the lock nut off one end and ran the thread all the way into that piece. I put the lock nut on the other end and bottomed the thread out, then locked it agianst the rod end to align the two and lock the rod in place. This gave me the same 12" eye to eye that the original piece was.
I had to get one 5/16 X 24 X1" bolt and locking nut for the front mount and one 5/16 X 24 X1 1/4" bolt for the transmission lever. When I put the rod on, I found the front piece at the shifter seemed too close to the lever. I don't know if it would bind or not, but it was very close and may rub when downshifting. There wan't enough clearance to put the rod end behind the lever as the bolt would hit the cylinder fins.
I made a sleeve to shim out the rod at the transmission lever end. A few washers would do the same thing.
When installed this kicked the rod out just enough to give me some clearance at the Toe end of the works.
It's still snowing here and the roads are white with salt so it will be a few more weeks before I can try out all the mods I did this winter.
But the days are getting longer!
(Sump'in just ain't right. Harley Davidson didn't need any spacers and neither should you.)
I'm in the process of doing mine now and found the shifter lever hole to be .015 larger than the 5/16 diamerer I expected to find. Very sloopy tolerancing on the manufacturing of the lever. I will wrap the bolt with .007 shim stock to remove the slope.
I ordered shoulder bolts with a low profile allen head in stainless so i could place the front heim on the jug side of the lever and not rub the jug, you should keep the rod alienment as straight as possible. You should also use bolts that have a unthreaded shoulder to keep the fit tight through the front lever and heim to eliminate slop and thread diameter wear as the unit goes through thousands of cycles over time.
