Starter issues 06 FLHX
Old Feb 22, 2009 | 09:15 AM
tgaetto's Avatar
tgaetto
Default Starter issues 06 FLHX
Changed my comp gear to a 24T and progressively have acquired a starter problem? It seems to grind and fall off when turning over. I have compression releases so I am not sure what is going on. Is there a drive with a heaver spring or something like that? I Checked for bad ground and all wiring and contact areas are good?
This only started after the comp gear change?
Old Feb 22, 2009 | 09:27 AM
BadPiggy's Avatar
BadPiggy
How old is your battery?
Mine is 3 years old, getting kickback.
Time for a new battery, for me.
Old Feb 22, 2009 | 01:31 PM
tgaetto's Avatar
tgaetto
Battery is new?
Old Feb 26, 2009 | 01:45 PM
tgaetto's Avatar
tgaetto
Could this be the cause? The only thing I found was this concerning bad contact? I took the starter out and apart and absoultly no visable damage to any of the multiple gearing?
Old Feb 27, 2009 | 11:41 PM
tgaetto's Avatar
tgaetto
Took the starter to my friends over at Dispatch Automotive and had them go through the starter. I told them that I found no visible damage when I did it. They took the whole thing apart put it through a few testes and found nothing as well.
I am betting the picture posted is the cause, I will continue to update since there is so much interest!
Old Feb 27, 2009 | 11:53 PM
hog-doc's Avatar
hog-doc
Tony it sounds like the starter clutch is going out. Not something a bench test will find but a common problem. Not sure what the picture is showing other than maybe that the starter was loose and moving around on the case, which on an '06 would cause a bad ground.
Old Mar 9, 2009 | 12:28 PM
tgaetto's Avatar
tgaetto
Still hosed gonna change the starter clutch one of these days....
hogmann74
Shovelhead
11
Sep 20, 2022 07:27 PM
radio915
20
Apr 15, 2011 08:58 PM
rotorhd
Feb 8, 2008 08:25 AM
AcidRayn
Mar 4, 2006 10:24 PM
ackmoe
Nov 18, 2005 03:56 PM
