SG removable rack-need help
Old Apr 23, 2006 | 11:39 AM
spokes54's Avatar
spokes54
Default SG removable rack-need help
I'm installing a removable back rest and luggage rack on my new Street Glide and can't figure out if I got the wrong kit or there is another way of mounting the antenna. The rack support goes throught the hole in the fender filler where the antenna goes through. They both don't fit. Is there a fix for this? Perhaps another place to mount the antenna or do I have to ....gulp....cut the fender filler?
Old Apr 23, 2006 | 11:40 AM
Timex's Avatar
Timex
Default RE: SG removable rack-need help
Antenna under the fairing. Tune Trapper.
Old Apr 23, 2006 | 11:45 AM
wireman2511's Avatar
wireman2511
antenna will work it will go on the outside of filler i used wide spacer that comes in kit there is a threaded bolt hole that lines up perfect and u dont have to buy that 100 dollar relocate kit
Old Apr 23, 2006 | 11:48 AM
spokes54's Avatar
spokes54
thanks wireman-I'll give it a try
Old Apr 23, 2006 | 02:45 PM
udnudn's Avatar
udnudn
Had the same problem. Took that rack back and got the one that bolts to the backrest. Backrest on/rack on. Backrest off/rack off.
Good thing about the one you have is: You can run with backrest only, rack only, backrest and rack. After further review, I thought the scoot might look like it had tow rings for a water skier [sm=laughat.gif]with the mounts that you have to use with the rack you have. But if you plan on lots of long trips, that's probably the one you want --- you can add a tour pack to it at a later date. I personally like the looks of the *** end with nothing sticking out of the rear fender. [sm=smiley20.gif]
Go git ya a tune trapper for inside the fairing no matter what rack you choose. Then I payed 2 bucks for another ugly butt plug for the port side of the fender filler.
rog246
Sep 5, 2015 12:20 AM
djcos1
Jun 28, 2011 08:12 AM
Chuck1
Oct 17, 2010 07:16 PM
Jimbo59
May 19, 2008 08:24 PM
HD Renegade
Feb 21, 2006 08:04 PM
