Battery Tender
Old Mar 1, 2009 | 10:54 AM
snakeinct's Avatar
snakeinct
Stage III
Default Battery Tender
Easy question I hope. Will the battery tender still charge the battery with the maxi fuse pulled? I have the tender plugged into the factory plug on my 2008 Ultra.
Old Mar 1, 2009 | 10:57 AM
neonhomer's Avatar
neonhomer
If the plug is after the fuse, then no. If the plug is wired DIRECTLY to the battery, then yes.
Old Mar 1, 2009 | 10:59 AM
EG Ultra Classic's Avatar
EG Ultra Classic
Trace back the "factory plug" on the bike. Does it attach directly to the battery? If so, then maxi fuse makes no difference in or out, it will charge the battery. Mine is connected directly to the battery. I didn't know the factory installed tender plug ins. I puton what came with the tender.
Old Mar 1, 2009 | 11:00 AM
soos's Avatar
soos
Just curious, why would you have the maxi fuse pulled?
Old Mar 1, 2009 | 11:21 AM
snakeinct's Avatar
snakeinct
Stage III
EG, my bike came with a battery tender plug already wired in just below the right side cover. I'll look to see how it's wired in. I want to pull the maxi fuse so I can remove the inner fairing for painting and I don't want to start removing all these wires with power going to them.
Old Mar 1, 2009 | 11:24 AM
rbabos's Avatar
rbabos
The tender should show if it has the required connection with the light indicator.
Ron
Old Mar 1, 2009 | 11:27 AM
EG Ultra Classic
OK, simply take a volt meter and hook it to the bike's tender plug. It should read 12v. Now unplug the maxi fuse. If it still reads 12v then it is wired hot to the battery.
Old Mar 1, 2009 | 11:39 AM
snakeinct's Avatar
snakeinct
Stage III
Easier still, I followed the wires from the plug. They connect directly to the battery. Thanks for the replys.
Mike
captainron62
Screamin Eagle CVO Models
Nov 28, 2013 08:40 PM
Sandcrab
Electrical/Lighting/Alarm
Mar 2, 2010 10:36 AM
phkrider
Dec 12, 2007 08:00 PM
dr_trousers
Aug 19, 2007 10:27 AM
boneman
Apr 23, 2007 07:39 PM
