Security question
Old Mar 2, 2009 | 07:55 AM
TMART's Avatar
TMART
Default Security question
Hey,quick question.If I dissconnect the battery to install a battery tender,will I have to relearn the security code or does it stay in memory?
Thanks
Old Mar 2, 2009 | 07:58 AM
Rufus4bz's Avatar
Rufus4bz
I just installed an amp and had to remove the battery connections. The alarm retained all the info it needed.
Old Mar 2, 2009 | 08:02 AM
Raaze07's Avatar
Raaze07
Same here. No issues on either my '07 SG or the new Ultra.
Old Mar 2, 2009 | 08:05 AM
TMART's Avatar
TMART
Sounds great,thanks for the replies.
Old Mar 2, 2009 | 09:03 AM
ucommbxny's Avatar
ucommbxny
had battery disconnected for about two weeks hooked it back up, and bike started no problems
Old Mar 2, 2009 | 09:44 AM
gmurdock's Avatar
gmurdock
I have an 09 Street Glide & I disconnected the battery to install new Fog Lights & everything works and it starts no problem.
Old Mar 2, 2009 | 09:54 AM
dawg's Avatar
dawg
If you are talking about installing the battery tender pigtail, check before you go through unhooking it, etc. Many dealers send the bikes out the door with a pigtail already installed. Yours may have one on it already.
Old Mar 2, 2009 | 10:22 AM
TMART's Avatar
TMART
Ok,I will check for that pig tail.That would be nice if is already on there.
Thanks
Old Mar 2, 2009 | 06:16 PM
JustDennis's Avatar
JustDennis
Also, turn the switch on first then pull the Maxifuse before disconnecing battery. If you don't the alarm will remind you it is there if you have a siren installed.
Old Mar 2, 2009 | 06:31 PM
hdbe's Avatar
hdbe
what is the maxifuse?
