Loose rear shift arm
Old Mar 7, 2009 | 06:15 PM
gary_montague's Avatar
gary_montague
if you spleen is coming out you should call 911.
Old Mar 7, 2009 | 06:43 PM
Point Man's Avatar
Point Man
While your down fixing that shifter arm, check the front shaft where it goes into the outer primary. You might find some play in that that one too (I did last year). I replaced the front shaft and rubber bushing, which helped tighten things up as well as a new shifter arm where it goes into the tranny. There are also 2 steel bushings inside where the front shaft goes that can be replaced but the old ones have to be pressed out first. It's still started to loosen up a little after some riding but is much better than before.
That shaft that comes out of the tranny (with the teeth on it) is called the shifter pawl assembly. You have to replace the whole assembly from inside the tranny to do it right.
I'll end up doing one eventually; most of us do (at least once). See some other past threads on this topic.
Old Mar 7, 2009 | 09:24 PM
Beemervet's Avatar
Beemervet
Just go ahead and replace the shifter pawl (splined shaft). That is the real problem, very common.
Old Mar 7, 2009 | 10:57 PM
leon anthony's Avatar
leon anthony
those bushing can be driven out you don't need to press them out I have changed
mine and it realy tighend things up nice
Old Mar 10, 2009 | 09:00 PM
CGLTD's Avatar
CGLTD
Thanks for all the replies! I ended up just getting a replacement bolt to see how that goes and it tightened up good and was fine on a test ride.
Old Mar 11, 2009 | 12:42 PM
ponomo's Avatar
ponomo
Default Mine too
My shifter pawl is loose also, just found it after a pretty long ride. I must have jammed on the shifter too hard.
It looks like I have to remove the primary to replace it?
I like the idea of changing the allen screw personally.
smokewagon
General Topics/Tech Tips
Jun 5, 2015 12:21 PM
ponesma
Jul 15, 2014 09:15 PM
garcon
Feb 23, 2011 07:55 PM
scooter_trash_1
Oct 12, 2010 06:51 AM
HOG_0308
Aug 8, 2010 08:54 PM
