Useless air temp gauge
Old Mar 12, 2009 | 05:40 AM
MNPGRider's Avatar
MNPGRider
Lots of posters here in the past have stated they increased the accuracy of the gquge by moving the senser unit out from under the fairing and into the air flow. It's on my list of to-do's, but never got a round tuit yet.
Old Mar 12, 2009 | 06:13 AM
StreetGlideMedic's Avatar
StreetGlideMedic
Originally Posted by JohnScrip
I dunno... One day last summer I was riding and thought "Holy crap is it HOT out here..." A glance at the thermometer did indeed confirm that thought. And just a few days ago (in the low 30's) I was freezing my knap sack off on a short ride. Once again, the thermometer came to my rescue as it most definitely read a much lower number.
In a car, you'd possibly have to open a window for such accuracy.
Hmmm...So what you're saying is that there is a reason for the Ambient Temp. Gauge...and one way we can measure the effectiveness of the gauge is to roll the windows down on our scoots and check the outside temps! Alrighty then...I'm gonna try it!
Gee...can ya tell I just woke up and feel silly stupid this morning??
Ride Safe, Mike
Old Mar 12, 2009 | 08:13 AM
slime_dog's Avatar
slime_dog
I fixed mine!
The sensor is mounted high in the faring! That is a silly place for a temperature sensor! HEAT RISES! There is no where for the heat to go inside the faring since it is not vented.
I simply moved the sensor down lower in the faring near an opening where some airflow occurs. It is not easy since the leads to the sensor are rather short. A little rerouting and harness separation got the unit to the desired location.
Now, my thermometer is no further off than a few degrees and that is as close as the resolution of the dial.
Old Mar 12, 2009 | 08:16 AM
iclick's Avatar
iclick
Originally Posted by hover
So, I'm thinking nobody is happy with the air temperature gauge accuracy, what does HD say about it? Surely they must have a solution...after all it is just a thermometer. I know, I know but I still want mine to read properly. Has anyone figured it out?
Yes, I've figured it out, and we should thank HD for their innovation:
1. It is a precision instrument that accurately measures the air temp inside your fairing. If the sun is shining it will be 20° hotter than ambient. If cloudy it might be about equal. Thus, the ATG doubles as a sun gauge, so you have two gauges in one. I ask, why are we complaining?
2. By installing the ATG as standard equipment it makes some picky owners want something else. Enter the oil-temp gauge, for sale at your HD shop for only $140 that provides useful info about the operation of your engine. It is up to the owner to determine if this is more important than the air temp inside his/her fairing. Thus, they ultimately sell you two gauges, an ATG and an OTG. This is very savvy marketing strategy and we should all admire this.
Old Mar 12, 2009 | 08:43 AM
hawg08's Avatar
hawg08
I ignore mine as it's nothing more than a useless "hole filler".
Old Mar 12, 2009 | 09:00 AM
Theakerr's Avatar
Theakerr
Living up in the Great White North and trying to maximise the riding season, I ride in the early spring and late fall. During this time I can start riding at +10 but by the end of the ride it can be -1 or lower. I want to know what the temp is doing more accurately than seat of the pants for at least a couple of reasons (Hypothermia, which as it occurs actually gives a false impression of temperature and ice formation). So I bought an "Icetracker" from Aerostitch and replaced the HD air temp with a HD Compass (Another totally useless piece of junk and waste of money). Re the sensor, on a 2003 FLHTCi I did consider trying to re-locate the sensor but was told that the wire was very short and that it was effectively impossible to relocate it and that it is a calibrated length so that splicing in is not an option. I must admit I did not check for myself, can anyone confirm and tell me what colour the wire to the sensor is.
Old Mar 12, 2009 | 02:17 PM
tzman's Avatar
tzman
My 06 Ultra temp ga was useless, but the 09 Ultra is much more accurate. It seems to be in a more appropriate spot
Old Mar 12, 2009 | 02:29 PM
nvsteve's Avatar
nvsteve
I spliced and moved the sensor to outside and below the fairing. It's now accurate on the higher temps (used to be around 20 degrees high on hot days) and off quite a bit on colder days. Maybe you were told correctly about the length of the wire.
Old Mar 12, 2009 | 02:47 PM
rochkes's Avatar
rochkes
I don't care to have a temp gauge on my bike. I know when I am hot or cold without knowing what the actual temp is, but mine is as accurate as any temp gauge I have ever had in any vehicle.
I used to think it was always reading high, but then I noticed one day that it was the angle I was looking at it that made me think that. When I studied the marks on the gauge and looked straight on, it is accurate.
Dennis
Old Mar 12, 2009 | 04:52 PM
leohd's Avatar
leohd
the gauge is made in taiwan and shows the temerature in that country
