New Stabilizer - Again!
Old Mar 25, 2009 | 06:52 AM
  #41
Jinks's Avatar
Jinks
Originally Posted by gunner11
Don't get the wrong Idea, I'm not trying to get it to wobble, jst trying to find out the average speed the guys ae talking about when they say high speed sweepers. I ride within my limits all the time, and very happy doing so.
And I'm trying to point out that despite the large number of riders with pre-'09 machines that insist they have no problem since they haven't experienced a "wobble", the problem still exists. I'm sure that in some cases a lack of experience is part of the problem, but without knowing the experience level of each rider I don't want to offend anyone.
The two points of my post were that first, a stabilizer will improve the ride at any speed & all conditions. And second, that the longer you can say "I've never felt a wobble" the better off you are. Wobbling can happen at a lot of different speeds depending on conditions. Improper steering head bearing tension, tire pressure, & alignment can all contribute to instability as can road surface. Your body position, & even the clothes you're wearing can have input since it's all part equation, so there is no one speed where these things occur. All motorcycles are subject to those issues, but Harley added the challenge of a flexible frame to drive train interface. On a $20,000 machine it seems reasonable to me to invest between $175 & $400 to keep all that shiny stuff shiny & the rider alive.
Old Mar 25, 2009 | 06:59 AM
  #42
VT Hog's Avatar
VT Hog
I had the wobble and took the easy way out. I got a set of Sta-Bo bushings and installed those. I paid under $100.00 and they are just as good as any stabilzer out there. My father has a stabilzer and he prefers the ride of my bike. We will be changing it out this month..
http://sta-bo.com/_wsn/page2.html
Old Mar 25, 2009 | 09:15 AM
  #43
ROGERinSEMO's Avatar
ROGERinSEMO
Default Hey Craigoh
How hard were the Sta Bo to install? Any Vibration issues? The old white Sta Bo or the new ones? Thanks!!
Old Mar 25, 2009 | 11:47 AM
  #44
VT Hog's Avatar
VT Hog
New ones and they took about 1 hour. Pretty simple install if you are mechanically inclined...
No Vibrations or issues at all..
Old Mar 25, 2009 | 01:22 PM
  #45
gunner11's Avatar
gunner11
You make a valid point, one I will consider.
Old Mar 25, 2009 | 05:58 PM
  #46
ROGERinSEMO
Did you have to take the pipes off? Are they just bolted into the swing arm side plates? Do the sta-bo go in from the front or the back side of the swing arm plate? Do you have to take the swing arm plate off? THANKS!!!!!!!
Old Mar 26, 2009 | 09:13 AM
  #47
poppa cooter's Avatar
poppa cooter
before i would buy any of those i would check my belt tension, had my tires changed and the indy had my belt loose and it wobbled around corners had my belt tightened back up and all wobble went away.
Old Apr 2, 2009 | 08:49 PM
  #48
gordon188's Avatar
gordon188
I purchased the progressive a couple of weeks ago, Installed it this afternoon. Pretty straight forward install, the swing arm bolt on the bottom, you have to remove the exhaust. My son and I loosened up the exhaust and had enough wiggle room to get the bolt in. I did take it for a short ride this evening, and couldn't really tell the difference. Pretty much straight driving and the long sweeper that I wanted to try had deer on both sides of the road, hence, I went about 25. If we have another day like today, I will ride the wheels off and report back, I think they are listed back on ebay. http://cgi.ebay.com/ebaymotors/PROGR...1%7C240%3A1318
Old Apr 2, 2009 | 09:04 PM
  #49
barjbar's Avatar
barjbar
I have the Bagger Brace and it works great. In the May issure of Cycle World it states after testing the '09 Ultra:
"You'll wonder where the wiggle went. Since 1983, all FL tourers have rolled on that same chassis, which has undergone only a few changes along the way. That chassis nicely isolated the occupants from engine vibration, but the rubber mounts also meant the big V-twin motor could not serve as a stressed frame member, thereby compromising the handling. FL's ever since have been inclined to wallow when cornering on bumpy pavement, especially two-up, and sometimes wigggle when running over longitudinal grooves and seams in the pavement".
Old Apr 2, 2009 | 09:32 PM
  #50
FX4's Avatar
FX4
Originally Posted by BC Glide
If you haven't had the wobble yet consider yourself lucky. I have a bike that is prone to it to the point I have considered selling it. I have just received a bagger brace and hope it will cure the problem. The fir and finish of the Bagger Brace looks great. I will let you know if it helps as the snow is finally gone now.
Bet it does, the Bagger Brace is awesome. Made my bike feel like an entirely new bike.
