I give up
Old Mar 24, 2009 | 06:23 PM
bluebagger's Avatar
bluebagger
Default I give up
I have a squeaking sound on my 08 RG that appears to be comming from the windshield, at the bottom where the thing attaches to the faring. For the life of me I can't find out what is causing it. I push up on the windshield and it stops, when I release the pressure the noise is back. I'am at my witts end trying to figure it out. Hate rattles or squeaks.
Old Mar 24, 2009 | 06:29 PM
mastery's Avatar
mastery
Do you have weatherstripping between the windshield and the outer fairing (it would be seen near the top of the fairing, and seals the windshield water from going into the fairiing like a waterfall)? I had a squeak in my bike there. When I replaced the windshield with something more custom, it came with a weatherstripping piece. Didn't have a original piece from the factory in there, so put it in, windshield in place, and squeak is gone. Not sure if my bike was supposed to have the weatherstripping, but the one I put in helped.
Also, make sure your three upper outer fairing screws are snug that hold the windshield in place.
Old Mar 24, 2009 | 06:31 PM
AZCFH's Avatar
AZCFH
thought i read on here somebody removed the rubber moulding at the bottom of the windshield completly for the same concern. mine squeeks once in a while .i'm thinking of trying that first myself ..
Old Mar 24, 2009 | 06:32 PM
flhtupser's Avatar
flhtupser
#1 on the weatherstripping.
Old Mar 24, 2009 | 06:51 PM
Bobzilla's Avatar
Bobzilla
If it is the weather striping maybe you could spray a little silicone spray in the area works on my pickups weather striping
Old Mar 24, 2009 | 07:18 PM
richro123's Avatar
richro123
I put some clear silicone on the seal to hold it to the windshield and then CAREFULLY tighten the screws. If you overtighten the screws you will crack the windshield (Spider cracks). The silicone is only to hold the seal on and keep it from moving around.
Old Mar 25, 2009 | 02:40 PM
Keith E.'s Avatar
Keith E.
Screws tight? Ask me how I know.
Keith
Old Mar 25, 2009 | 04:06 PM
cooper57M's Avatar
cooper57M
i had a sqeaking sound too. It was the clutch lever at the pivot that making the sqealk. There is a white plastic piece around the lever pivot area that rubs and made it squeak. Lubed it up dielectic grease.
EasternSP
2014-2024 Touring Models
17
Sep 30, 2017 04:02 PM
cruzin924@yahoo.com
Aug 12, 2014 05:24 AM
dchoran
Apr 4, 2009 06:37 AM
tmoreau
Sep 6, 2007 06:50 PM
AZFLHX
Jun 6, 2007 11:14 AM
