Hey all! I've got a potentially silly question. (AGAIN!)
I bought an FLHX rear fender fascia that came with the tri-bar running light in it. Well - it's burned out. (It was a take off from a wrecked bike)
I want to either get a new light kit, or upgrade to the tri-bar run/brake light kit. (68358-07) Here's the question:
If I get the run/brake light, will I have to splice wires? After looking at the pic online, the wiring doesn't look long enough to go the the wire under the seat. My guess is that it has to go to the harness under the tail light.
Any ideas?
ALSO - if someone has already upgraded their light - do ya want to sell your take-off?
I ride an '08 Road Glide, but the FLHX parts came off of an 06 FLHX.
The Street Glide tri-bar (LED) plugs into the tour pak wiring harness that is already on your bike. The connector is a black plastic three-wire connector and is quite long since it reaches to the back of the rear fender. Usually, its folded up and zip tied to the left frame rail under the seat or left side cover.
Alternatively, you can remove the connector on the LED and splice the wires to the two wires plugged into the upper left chamber of your tail light circuit board behind the tail light. If you have the SG turn signal bar, that upper left chamber is occupied with two wires for the license plate LED's in the turn signal bar. You splice the black wire of the SG LED to the left wire and the white/black wire to the wire in the right side of the connector--the center chamber of the connector is empty.
Good luck with your project.
PS: Do yourself a favor and buy the Service Manual for your bike; most, if not all, of the info you need is in it, especially regarding wiring.
I did the upgrade to the brakelight version. Had to run the wires up along the frame and connected under the side panel under the seat due to the shortness of the connector. Not sure why they made it like this, but thats what I had to do.
I do still have my stock take-off light boxed up if you are interested. By the way, my FLHX is an '09.
It is the tour pak lighting harness it will run right near your left fender strut or under that side cover. It is a simple small wire. Not a big deal at all.
