I am wanting to get a solo tourpack but I have a corbin solo seat and I was told HD tourpack wont work. Is there anyone out there that makes the rack for a tourpack with a corbin classic solo?
the milwaukee baggers tourpak rack may fit.... check with them. otherwise, do what the rest of us did, buy another seat (i have the c&c solo and like it lots)
Not so quick there, what you are probably going to have to do is, put the tourpack on first and then the seat and I'll bet it will work. I have to do the same when I run my Corbin Classic Solo with the touring pillion. Tour pack goes on first, then pillion, then the solo seat and it works like a charm.
this is correct -- put seat on last -- it will take a little squeezing but will work.
thanks guys. I might have someone interested in buying the seat. I might try and fit it the way you guys say. I wonder if I could space the tourpack up on the detach rack to make it better or if there is a rack that sits higher. Thanks for the help.
I don't think it's your tour pack thats hitting th seat, it's probaly the crossbar on the detachable rack and I don't see any way to adjust that. Try the method I described above and I'll bet it will work.
