Bitchin Baggers drop shocks mod
Old May 12, 2009 | 09:09 AM
  #31
Drtumolo's Avatar
Drtumolo
What air pressure does everyone run in their drop shocks from bitchin baggers? I just installed a set last night and wasnt really sure where to start at.
Old May 12, 2009 | 09:45 AM
  #32
FirewallFrank's Avatar
FirewallFrank
I just added the bitchin bagger 1.5" drop shocks to my Road King and I am completely satisfied. The wife and I w/ gear top close to 450lbs on the bike and I have not had any issues. I am running with 50lbs of pressure.
Old May 12, 2009 | 01:38 PM
  #33
Drtumolo's Avatar
Drtumolo
thanks I added the 1.5" drop shocks also. I only weigh @115lbs single and 2up maybe 230lbs. When they put together my shocks they went with a softer spring. I am going to try 20#s to start and go from there.
Old May 13, 2009 | 05:46 AM
  #34
Drtumolo's Avatar
Drtumolo
OK I tried 20psi seems to bottom out pretty easy. I guess I will just continue to increase pressure until it only bottoms out on the most severe bumps.
Old May 13, 2009 | 07:14 AM
  #35
VT Hog's Avatar
VT Hog
Originally Posted by JonnyD
Read above.......
Just because you have "touring shocks" doesn't meant they are the "StreetGlide" ones. If they are the regular touring shocks, they are 1.5"-2" longer still.
Just so you know.
RKC to Touring shock = 1.5" lower
RKC to Street Glide shock = 3" lower.
I put a set of StreetGlide shocks on my dad's RKC and his dropped a full 3" lower!
Old May 13, 2009 | 08:08 AM
  #36
Donald A's Avatar
Donald A
Just curious, how does BB do the mod to the shocks?
Old May 14, 2009 | 05:32 AM
  #37
Drtumolo's Avatar
Drtumolo
I am not really sure. The shock looks identical to stock only shorter stroke.
Old Jun 3, 2009 | 10:53 PM
  #38
youngsta's Avatar
youngsta
6th Gear
Does anyone have any before and after pics. Preferably 11.5 shock visual difference. I think my streetglide needs a 1/2 drop in d rear.
Old Jun 3, 2009 | 11:00 PM
  #39
OG1's Avatar
OG1
i have the 11.5 on mine, but came from the stock 13's. ill look for a stock pic from a similar angle
Attached Thumbnails Bitchin Baggers drop shocks mod-photo.jpg   Bitchin Baggers drop shocks mod-img_0238.jpg
Old Jan 22, 2010 | 10:13 PM
  #40
Jahillsr's Avatar
Jahillsr
I just got my shocks back from BB and will have them installed on my '98 RKC while the rear tire is changed next week. The invoice states 1.5" drop = 11.25". What would others suggest running for air # at 180lb one up and 340lb two up?
Thanks!
