Question re: removing fork tubes
Old Apr 14, 2009 | 10:28 AM
Hoffy's Avatar
Hoffy
Well thanks for the tips, it worked great and the tubes came right out of the fork tubes except for some strange reason after they came out I felt like having a cigarette! I don't have to send my bike any flowers in the morning do I? I hope my bike doesn't think I won't repect her in the morning.
I am surprised how easy the chrome fork slider upgrade really is. But than after the handlebar and switch cover change, everything will seem easy!
Old Apr 14, 2009 | 03:41 PM
fairplay's Avatar
fairplay
man did this thread ever take the wrong turn.
I will be doing my 09 shortly. how much oil did you add? I know the book tells one ammount but considering the residual did you put less?
Old Apr 14, 2009 | 06:53 PM
Hoffy's Avatar
Hoffy
Haven't added oil yet but I will do whats recommeded in the manual. After seperating the tubes and using new lowers I don't see how there could be much oil still in dampers of any amount that matters. Unless theres something I dont know about yet.
Old Apr 14, 2009 | 06:58 PM
lp's Avatar
lp
Actually the upper fork bushing is what holds it all together. Not the fork seal.
lp
Old Apr 15, 2009 | 11:23 AM
uweldit's Avatar
uweldit
Use 10.8 oz for 2008. You probably already figured it out.
Changing the lowers was a piece of cake, wasn't it?
Old Apr 15, 2009 | 11:29 AM
uweldit's Avatar
uweldit
Fairplay,
Get a manual and follow directions for adding fork oil. When you take the lowers off make sure to have a pan ready for the fluid. Once it's all drained out and the new lowers put on, the manual should give you an amount to add. For my 08 I added 10.8 oz. Use a measuring device and don't overfill. If you overfill you have to drain it again unless you have the fancy HD fork oil tool which you can't buy at the dealer.
laabdog
Apr 15, 2017 10:02 PM
rs87277
Jul 12, 2012 12:38 AM
neverdown
May 14, 2010 02:46 PM
jefnightrain
Feb 14, 2010 08:42 PM
hell hound
Jan 16, 2010 04:35 PM
