Hardbag latch pops open - how to fix?
Old May 14, 2009 | 08:46 AM
  #31
BUSTERK's Avatar
BUSTERK
This happened to me and it was the spring broke in the hinge. If the spring action is lost you can take the hinge assembly off, use a dremel grinder and remove the weld burr on both ends of the hinge pin. Drive the hinge pin out and recover the broken spring. Many dealerships have a supply of the small parts. Reassembly is a small pita because you have to preload the spring but a couple brews and a little patience gets it done. Then after every wash, lube em. Ride Safe, Doug
Old May 14, 2009 | 10:14 AM
  #32
gunner11's Avatar
gunner11
Keep them locked when riding, that will solve the problem.
madhunter60
Audio Systems
Aug 16, 2016 08:52 PM
calicojack1165
Jan 18, 2016 02:08 PM
tru510
Aug 22, 2012 05:19 PM
myillearth
Aug 28, 2011 08:15 AM
walleyeking48
Aug 17, 2011 04:59 PM
