Need help
Old Apr 26, 2009 | 01:06 AM
cwbymikey's Avatar
cwbymikey
1st Gear
Default Need help
I have a 2000 ultra classic, just had 6x9 and a amp added to my bags,
had them in stalled by a shop that has done hundreds, Problem is
while riding with the radio on,the bike will shut down and blow the fuse to my radio, I will turn the key off, wait a couple of secounds and restart my bike, the engine runs fine but the radio wont work, they ran all the wires under the fuel tank, I have checked pretty much everything, but pull the tank off and check for a pinched wire, any thoughts,
Thanks Mike
Old Apr 26, 2009 | 08:14 AM
1flhtk4me's Avatar
1flhtk4me
Does the shop warranty their work?
Old Apr 26, 2009 | 09:04 AM
MarkThomas's Avatar
MarkThomas
Um, ride back to where the stuff was installed and make them fix it?!
I wouldn't have even looked for the issue myself...you paid them to do a job, and they didn't do it right.
Old Apr 26, 2009 | 09:59 AM
StreetGlideMedic's Avatar
StreetGlideMedic
+1 on this! they should have a warranty on their work. Let them recede into the system and find the issue! Don't go playing with their work...cause if you do...they can say you caused the issue in the first place!
Good Luck and let us know what happens!
Mike
Old Apr 26, 2009 | 11:45 AM
cwbymikey's Avatar
cwbymikey
1st Gear
I did take it back to them, they checked all there work, no problem found with what they installed. I think there is a wire or something wrong under the tank .
Old Apr 26, 2009 | 01:56 PM
2003flhtci's Avatar
2003flhtci
Well, if it worked fine before and now it blows fuses after they did any kind of electrical work on it, it's hard to see how it couldn't be something they did. What do they suggest is wrong? Anything? If they've done that many installs they must be pretty familiar with the wire harness in general.
Keep banging on their ears, man. They need to make this right for you. Or tell them to uninstall it, get yer money back, and go to someone else. And if they won't stand behind their work, post who it was so the rest of us can avoid them.
Old Apr 27, 2009 | 02:23 PM
cwbymikey's Avatar
cwbymikey
1st Gear
I will do that, Once they tell me I am on my own,..Thanks for all the input.
Ride safe,,,
Havanacigar
2014-2024 Touring Models
May 16, 2017 02:15 PM
2AMGuy
Jul 31, 2016 07:45 PM
Electragliderider140
Audio Systems
May 31, 2011 09:47 AM
dgriffith
Oct 13, 2008 07:22 PM
nmfxstc
Feb 6, 2006 07:07 PM
