HELP! Weird electical problem today
Old May 12, 2009 | 09:11 AM
dawg's Avatar
dawg
Any burnt smell near the primary? Stator might be shot.
Old May 12, 2009 | 09:15 AM
gmc's Avatar
gmc
Screws, I'd bet it is in your handlebar lever clamp. Loosen and make sure the wires are in the handlebar grove.
Downsmith, Yes your voltage regulator can cause a problem like this, had it on my 00 Fatboy.
Old May 12, 2009 | 03:33 PM
downsmith's Avatar
downsmith
OK, found the "Accessory" fuse was blown, problem looks fixed for now. I will check the other stuff too.
Thanks!
Old May 12, 2009 | 04:57 PM
gmurdock's Avatar
gmurdock
Something caused the fuse to blow? Keep an eye on things for a while. Hope it was just a fluke sometimes that happens?
Old May 12, 2009 | 10:11 PM
screws4156's Avatar
screws4156
On the Money my friend...... Pulled the clamp checked the wire bundle. Found the pinched wire and reinstalled the clamp.... Every thing works just fine... Thank you for the help......
Old May 13, 2009 | 05:53 AM
Taterdog's Avatar
Taterdog
Screws, the wire must have been cut or torn during pinching. Did you fix the wire itself?
Old May 13, 2009 | 09:14 AM
gmc's Avatar
gmc
Glad that worked, sometimes the screws loosen and let the grips slide down on the bars and it cause the wires to pinch, supprisely it doesn't take much.
Update: I finally had to pull the switch housing and found the wires inside had rubbed a bear spot. I took a dremel tool and ground out where it fit threw the small sharp area. I guess after four grip changes I might have pinched the wires but there isn't much room in there. Usually if your blowing ignition fuses it's somewhere in the handlebar switches.
Old May 14, 2009 | 10:16 AM
downsmith's Avatar
downsmith
THAT was MY problem, too. Right side...
Rich
Old May 18, 2009 | 09:08 PM
grimlock's Avatar
grimlock
6th Gear
This helped me out...Found the wire that was grounding out-- causing the fuse to blow. Thanks for the quick fix!
GittinThere
Jun 3, 2019 07:41 PM
Titan56
Jul 3, 2011 09:44 PM
ffemtbiker
Jun 28, 2009 04:38 PM
ChefE
May 6, 2008 11:17 PM
ChefE
Apr 24, 2008 01:09 PM
