removing rear wheel
Old May 14, 2009 | 07:35 AM
patsac's Avatar
patsac
sounds good...thanks all !!
Old May 14, 2009 | 12:00 PM
roadking1893's Avatar
roadking1893
Marking the adjustment cam is a must that way you have a means to tell you are close when you adjust the tension. the size of the socket is 36 mil. You can't get a socket on the nut unless you removed the exhaust on the right side, the left you need to removed to completely removed the shaft. What I did was cut the soket in half and created my own version of what I call "Dog bone". Or you can take a 36 mil. box end wrench to loosen and installation. Make sure you tighten the nut and then back it off then re-tighten or it will work itself lose.
1stHD_95FXDWG
Mar 10, 2014 02:23 PM
Skippy97
Dec 25, 2013 06:46 PM
FinalShot
Nov 13, 2013 05:25 PM
big_e78
Mar 15, 2010 06:15 PM
ozzy07840
Sep 26, 2008 10:30 PM
