Axle nut
Old Mar 10, 2020 | 09:01 AM
805dwg's Avatar
805dwg
Such a big ***....umption EightEight. Just because someone makes or builds something doesn't mean they know what the hell they're doing.
And if your axle is spinning, your correct, that is a problem. Installed properly the only thing spinning is your head.
So, now that you all agree I'm right, only because I am, Ill explain it once more.
So for the older cats and the mental retar... I meant, the special ones who are here today, its very simple Eight Eight, pay attention
LEFTY LOOSEY
RIGHTY TIGHTY
You guys ever smoke weed? because maybe you should kinda cut back on it a little...Just saying!
SLater boys
Old Mar 10, 2020 | 02:01 PM
barneyboy's Avatar
barneyboy
Originally Posted by 805dwg
You boys done f**king around? The question is how come his nut is tight? The answer is when the axel is installed Properly, from the right side and the nut being on the left side, as you ride the actual spins in the direction of the tire and the nut stays tight. I see a lot of bikes with the axel installed backwards. People do this to avoid having to remove the exhaust pipe when removing the rear wheel. It is a mistake that can cause the nut to come loose in the axle to move. I know this from experience. Take the time to put it on right and it will stay tight.
Ok, resume obnoxious behavior.
This is the Touring Models forum, and the OP's bike is a 07 Touring Model. You are giving advice based on your Dyna experience. Do you have any experience with the 02 and up Touring Model rear axle, and the belt adjustment cam that is welded to the axle? FWIW, nearly all Touring Models have mufflers on both sides. There's nothing to be gained by reversing the axle to simplify wheel removal.
DarkManC
Mar 5, 2014 08:31 PM
falconbrother
EVO
Feb 11, 2014 01:14 AM
myking
Jan 13, 2009 06:19 PM
Bluestreak
VRSC Models
Sep 1, 2008 09:19 AM
