Trailer lights
Old May 20, 2009 | 03:52 PM
abate1's Avatar
abate1
Default Trailer lights
I have a 2007 EGC and pull a trailer, the LED lights for the trailer are wired with a diode on each side and work fine with the bike, I installed a Kuryakn Panaeca brake/turn module and now the trailer only has running lights. The brake/turn do not work on the trailer, bike side works fine. Any ideas/fixes???????
Thanks
Doc
Old May 20, 2009 | 03:58 PM
rc9636's Avatar
rc9636
Probably going to need a load equalizer module.
Old May 20, 2009 | 04:36 PM
TheShrink's Avatar
TheShrink
What kind of harness are you using? Where is it plugged or soldered in, before or after the Panecea? If you are using a Kuryakyn run/turn/brake controller, be careful, they overheat.
You may want to consider a Badlands Illuminator and then you can just solder your trailer lights in behind that.
Old May 21, 2009 | 10:26 AM
abate1's Avatar
abate1
trailer lights are wired in before the panacea module -- that was my first guess also
hutch1
Nov 29, 2014 09:11 PM
Raventhik
Oct 15, 2009 03:58 AM
abate1
May 20, 2009 03:48 PM
BarneyMN
Mar 30, 2009 03:57 PM
Potato_Potato
May 6, 2007 12:09 PM
