i thought about doing the exact same thing. and thought that if you were to lay some flexible tubing for a mock up, to re route the hoses, it would work. then i got ta thinking, there may be a reason they're routed the way they are, for example, condensation in the line freezing when it gets cold, or the way they might need to flex to fit the connectors. heck i don't know. all i know is that they work, so i've decided to give up on trying to outthink the engineers who designed the system. it could have been done in a much more hidden way though i'd think.
I don't see why you can't reroute the hoses as long as you find a path that won't rub or melt the tubing. There may be a good reason for how they are routed ... then again, it may just be the simplest way using the least amount of hose. Keep the assembly line as simple as possible.
I got no instructions or pictures, but last fall a mouse got under my seat and chewed my shock lines into little pieces overnight. I replaced all the line, routed it the way it looked best to keep it out of sight and it has worked well with no problems. It is just air line, as long as it doesn't rub or get pinched, shouldn't matter. WIth the quick disconnects on the fittings it takes longer to take the seat off and put it back on than it does to route and connect the lines.
the plastic tubing is not expensive. I put a hole in mine last year and picked up some new hose from the dealer for $1 or $2. If I was looking to reroute the lines, I'd probably buy some new tubing and leave the exiting line in place until I had it finished.
The hoses just fit over the existing anemic air hose. The chrome fittings hold it in place with a hex screw (Although looking at the pict just now I see it has pulled out).
